Hi all,
Is there a specific "optimum" bias for a class AB amplifier, independent of the emitter resistors in the output pair?
I have an amplifier that uses a uPC1270H with 28V rails and 0.1 Ohm emitter resistors.
The amp has 4 channels and one appears to have been much more heavily (ab)used than the other; dried up small value caps, drifted carbon resistors, etc.
It lacks bias pots and the bias is set with fixed value resistors. The bias current across the emitter resistors in the "good" channels measure consistently at around 30mA (3.1mV across the 0.1 emitter resistor) whereas the "bad" channels differ from each other and are higher at 40-50mA.
I want to fit pots and re-bias the amp but have no figure to set the bias to.
Is there any rule of thumb or calculation applicable in these circumstances?
Optimum as in lowest distortion means choosing both optimum emitter resistors and optimum bias current, and these depend on the load resistance.
A wing-spread diagram is the best way I've found of visualizing cross-over issues (gain against input voltage - though the gain of an output stage is a slight attenution), there are some examples in this thread:
https://www.diyaudio.com/community/threads/power-amp-output-stage-measurements-shootout.374367/
Isn't the 'Oliver' criterium 26mV across Re?
https://hifisonix.com/power-amplifiers/cross-over-distortion/
Should also be in the above linked HP journal.
Jan
Jan
See page 11 here:
Thank you chaps, I'll have a read of those links.Optimum as in lowest distortion means choosing both optimum emitter resistors and optimum bias current, and these depend on the load resistance.
Thank you, will have a read. Had not come across the term "Oliver Criterion" before but did recall seeing the figure of 26mv across the emitter resistor. In this case that seems far too much, Is that figure meant to between both emitter resistors (negative and positive half of the output pair) or just one?Isn't the 'Oliver' criterium 26mV across Re?
Jan
Actuallu Oliver said 'between 14 mV and 26mV', and Russell found that with much lower value it worked fine.
I guess you really need to read the links and see what they say. The hifisonix is clearest.
Jan
Jan
26 mV (which can result in 100mA or more bias current) may be the optimum, but very useable results are obtained down to about 10% of that, especially if EF3 is used. Usually they cut it in half to a third and call it good.
There are too much talk about EF1 optimum bias point which straightly trasfered to EF3 optimum bias.
EF1 and EF3 are so much different that even thought about this are nonsense.
30 to 45ma per device is fine
if with differential depending on performance
feedback takes care of the rest
or depending on compensation additional bias
wont change the numbers much
With a amplifier that can actually show
or measure any significance with additional bias.
80ma to 100ma per device can be closer to ideal
You mean EF2, although EF1’s optimum is the same and even MORE sensitive. But useless for practical output power.There are too much talk about EF1 optimum bias point which straightly trasfered to EF3 optimum bias.
The EF3 certainly hits diminishing returns much sooner than EF2. Then the DRIVER quiescent dominates. Usually, the more the better because it results in smaller Rbe values which will allow faster charge suck-out in the output bank.
- Theoretical "optimium" bias for a class AB amplifier?
