Consider swapping places with the 0.1uF decoupling caps and small electros to bring the critical parts closer to chip amp power pins.
The 0.1 uF parts look big. Shop for smaller pin spacing (5mm) narrow leads means better HF performance.
Consider wiring the amp output speaker return going off PCB to the stiffer PS PCB instead. This is key to keeping a quiet gnd on the amp board esp since you choose very small value electos.
look at other chip amp power PCB layouts for ideas on central grounding. Think about all yer in /out connectors, their location, connection numbers, and chassis wire dressing with either a mono block, stereo, or even a HT amp for a future growth configuration. IMO Bunching all the ins and outs together in the middle with a circular ground is kinda like painting yerself into a corner.
Yes, take account of the wiring/trace resistance.In the simulation below, do you want to feed your amplifier with V1, V2 or V3?
Using V1 is a good way to have mains hum on your speakers.
An ordinary Capacitor Input Filter is actually an rC filter. Don't throw away that useful small r by connecting to the wrong terminal.
Similarly the bank of caps have connections all with a small r. Power comes out cleaner at the opposite end from the rectifiers. Looks like a 15dB reduction in hum/buzz. Note also the frequencies in the hum of V1 ref V3. V3 is substantially 100Hz and a few odd harmonics.
V1 is very spiky and consists of substantial HF harmonics.
Wow a huge thankyou to you 🙂 Finally I can visualize what is going on!
PSU design has been altered accordingly (I hear 4 caps are the new wave 😉)
Amp design was also changed quite a bit. 0.1uF caps were moved closer to the power pins, also were exchanged for 2.54mm spacing instead of 5mm.
Also Cin was moved closer to the chip, reduing the path from input to chip significantly. The AMP PCB is at the moment just below 10mm^2.
I'll keep that in mind and will try it if I have problems with noise on the speakers, but for now I keep the return on the AMP PCB itself (one less connector 😉).infinia said:Consider wiring the amp output speaker return going off PCB to the stiffer PS PCB instead.
Hopefully the nearly last revision:
AMP v3.0:
PSU v3.0:
The Parts list:
Some changes were made to the layout, the size of some of the components were updated. The speaker out was moved out of the 2.54mm grid, to allow for bigger drill-holes/connectors. For Cs1/Cs3 caps with either 5mm or 2.5mm grid can be used with a diameter up to 8mm. The input was moved into a 3.5mm grid that allows for PCB-connecters with screws (or whatever they are called) The purple box outlines the plastic casing.
also I've decided to call it the "mü-amp" 🙂. Size of the board is 40mm * 24mm = 9.6cm².
After printing it today for the first time, I have some doubts whether it is possibly to toner-transfer the PCB... but well, we'll see.
AMP: v3.1
PSU: unchanged
Parts List:
As always, further suggestions/critics welcome, around next week I think I will order the parts and build it, when everything fits, I will publish the layout of the mü-amp.
thank you everyone again, I really appreciate the effort you take helping some "random stranger" 😉
Cheers!
Code:
-LM3886TF x1
-Cin: Wima MKS-2 4.7uF 50V= 5% 5mm *1
-Cz,Cs2,Cs4: Wima MKS-02 0.1uF 63V= 20% 2.5mm *3
-Cs1,Cs3: Panasonic 68uF 35V 20% 2.5mm Inpedance:0.35Ohm Ripple:290mA *2
-Rm: 10k 1W *1
-Rf: 22k 0.25W *1
-Ri: 680R 0.25W *1
-Rg: 22k 1W *1
-Rz: 2R7 2W *1
AMP: v3.1
PSU: unchanged
Parts List:
Code:
-Cn: Jamicon 4700uF 35V 20% 7.5mm *8
-Dn: MUR820 *4
Cheers!
Nice work. How about not to connect the zobel and the speaker return on the signal ground bus?
An-1849, fig 11 may be useful for your design.
You may also consider fit the Rm under the Lm3886 and move the Rf closer to the chip.
Leave some space for the feedback cap and RF filter as well.
3.5mm pin/pad pitch does not sound right.
Almost all connectors use increments of 0.1inch (2.54mm) for pitch, The screw down terminals are usually 0.2inch (5.08mm) pitch. The single in-line pin and socket are usually in 0.1inch (2,54mm).
Mica (silvered mica caps) are usually not available in 0.1inch pitch increments.
What do you mean? Technically there is a connector on the AMP for the speaker return, but should anyone want to build this, he/she can still return the speaker directly to the PSU.Nice work. How about not to connect the zobel and the speaker return on the signal ground bus?
They are from: RIA CONNECT Article: 310591023.5mm pin/pad pitch does not sound right.
I'm not using any 😉Mica (silvered mica caps) are usually not available in 0.1inch pitch increments.
cheers!
The output zobel actually belongs on the amp board or the signal ground. Contrary to some folks belief this RC network is NOT for the speaker. It is used for feedback stability ie phase margin around the unity gain frequency > 2MHz. Due to high frequencies, when wired remotely, it's almost useless. It's very important not to mix power and signal grounds, so it's good to wire the speaker return to the PS common (power ground).
Also since this a gain clone copy, ie minimal design
A) there is NO DC block on the inverting network. so it's possible to have significant DC offsets at the speaker.
B) there is NO RF filtering either on the input or output. The user can and should provide some provision for this in the final design. Same is true on the PS PCB.
there is a short between pin 10&11 and pin 7 doesn't need to connected to ground via such a large track width, 0,5-1mm would be enough
Yep, but since pin 11 is not connected, it doesn't matter and I wanted to give the input line more room.
Wait isn't pin 7 the ground pin on the board? where at least the dissipated power flows through?
infinia said:Also since this a gain clone copy, ie minimal design
And again I have no idea what this is about 😱 could you explain this a little bit further/point me in the direction where I can read about this?
Since I plan to use single sided PCBs with a dimension of 120x80 it would still be convenient to have a 40x30 board rather than 40x24 now.
mü-amp v3.1
Some minor changes, I moved some parts around to use caps with 8mm diameter, and nearly four times the capacity, 2.54mm pads are still present, so updated:
Code:
-Cs1,Cs3: Panasonic 220uF 35V 20% 5mm Impedance:0.09Ohm Ripple:730mA *2
cheers!
Just for the fun of it I made an even tinier version, with smd components(the dark blue stuff). Enjoy 😀
nü-amp:
nü-amp:
The NS schematic with some parts marked "optional" are not really, except for advanced users or risk takers. The major item that impacts your amp PCB is the DC blocking cap in series with Rg. almost everything you need is in the NS data sheet.
RF filtering on all inputs / outputs including AC entry, is generally good design practice and depends on the PCB final application circuit/s or parts, layout wiring, and chassis design.
We could all make the chipamp smaller if we choose to omit essential components.
That choice comes at the expense of reduced reliability.
AMP v4.0
New: RF-Filter to Input/Output
New Parts:
cheers!
New Parts:
Code:
Cc: BCC 220pF 50-100V 5% 2.5mm *2
Rb: 10k 0.25W *1
R: 10R 2W
L: 1uH 7.5A 0.6mOhm 5mm
cheers!
Ah sorry typo..
Rb: 1k 0.25W *1
With updated, slightly more separated return of the speaker.
cheers!
Rb: 1k 0.25W *1
cheers!
I cannot agree with your layout philosophy of mixing the Signal Ground with the everything else Ground.
I recommend that Signal Ground and what needs to be connected to it, be kept completely separate from the Power Ground and Zobel Ground and PIN7 Ground and Speaker Ground.
Agree 100% with Andrew on this point 🙂 The data sheet is your friend.
You might note that this is a larger excerpt to what I posted before 😉
Tony.
LAYOUT, GROUND LOOPS AND STABILITY
The LM3886 is designed to be stable when operated at a
closed-loop gain of 10 or greater, but as with any other
high-current amplifier, the LM3886 can be made to oscillate
under certain conditions. These usually involve printed circuit
board layout or output/input coupling.
When designing a layout, it is important to return the load
ground, the output compensation ground, and the low level
(feedback and input) grounds to the circuit board common
ground point through separate paths. Otherwise, large currents
flowing along a ground conductor will generate voltages
on the conductor which can effectively act as signals at
the input, resulting in high frequency oscillation or excessive
distortion. It is advisable to keep the output compensation
components and the 0.1 μF supply decoupling capacitors as
close as possible to the LM3886 to reduce the effects of PCB
trace resistance and inductance. For the same reason, the
ground return paths should be as short as possible.
In general, with fast, high-current circuitry, all sorts of problems
can arise from improper grounding which again can be
avoided by returning all grounds separately to a common
point. Without isolating the ground signals and returning the
grounds to a common point, ground loops may occur.
Tony.
Just to make sure we're on the same page here, the marked grounds are those that the datasheet speaks of right? the common ground point can now be either on the AMP itself or on the PSU as I understand it. (I assume with the cGND on the AMP it is better to have seperate grounds on the PSU)
And interpreting the datasheet, Those GNDs should be returned individually, except for (low-level) feedback and input?
Note to self: Get better in english >.<
- Chip Amps
- The yet tiniest single-sided LM3886?
