the IC is a very nice circuit, unfortunately the LME is obsolete since not so long time
seems that TI wanted to sell more of their own class D solutions instead of the old school class AB circuit... i designed an amplifier with the LME which is going 6 times in a dsp based 6 channel active speaker system
but with my own pcb layout. good that i have saved some spare parts when i designed them 3 years ago...
Anybody interested in 2x PCBs, 2x2 ALFETs and 2x LME49830 ICs? I will never finish them...
Hi...UrSv
I need 2x Lme49830 ICs and mosfet also
Hi...UrSv
OK, I'd prefer to sell all of it.
Dear UrSv,OK, I'd prefer to sell all of it.
Pls give me a link on ebay for 2xLME49830 and 2xPcb ?
Hi UrSv,
Which schematics did you use ?
Jacques
Hi UrSv,
Jacques
The one from the GB.
or the "transformer".......hi,
how much Ampere the power supply needs to make this integrated (LM49830) work well ?
Thank you very much for your help...
Cesare
thanks.......
HI, thank you for your kind reply
yes ok
but I'm interested know how much current (LM49830) use the integrated for work???
something like ( drive current, 56mA ) for work +/- at 62Vdc
Thankks....... Cesare..........by Venice
The power requirements for the transformer is dependent on your final design. 25 watt output 100 watt output 150 watt output, mono, stereo, 5 channel? 4 ohm 8ohm?
I used a transformer from an old Kenwood stereo amplifier.
yes ok
from the data sheet Idle current is around 19 ma typical max is 24 ma with no load.
from the data sheet max output current is 54 ma
so worst case 24 + 54 ma
here is the data sheet
so with a 30VA(ma650X2) transformer I'm more than safe.
Many thanks "multisync".....
have a good day.......... Cesare from Venice
Dear All,
How to setting bias LME49830 based on this schematic, I use a pair mosfet 2SK1058/2SJ162.
Hi Toni, I have finished your SA2012 power amp using your pcb boards and I have a question please.3U and 4 channels can work perfectly:
http://www.diyaudio.com/forums/soli...84.html?highlight=sa2012+lme49830#post4643484
and
http://www.diyaudio.com/forums/soli...65.html?highlight=sa2012+lme49830#post3753565
4 x 190W@8R, about 250 - 300 mA bias total per channel. 3 Pair IRFP240/9240 per channel.
2 of 4 channel can deliver the 190W continuous without heat problems.
Maybe you need 5U cooling if you plan to deliver all 4 channels full power continuous.
BR, Toni
I am using +- 74Vdc lines, if biasing the fets using a 1.0 ohm resistor in series to the rails what is the desirable voltage drop across it?
- "The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets
