The Well Tempered Master Clock - Group buy
I'll add myself to the list:
- andrea_mori: 3 x SC-Cut 5.6448 MHz + 3 x SC-Cut 6.144 MHz
- fralippo: 2 x SC-Cut 5.6448 MHz + 2 x SC-Cut 6.144 MHz
- gentlevoice: 1* SC-cut 6.144 MHz
- gabor80: 1 x SC-Cut 5.6448 MHz
- lindamar: 1 x SC-Cut 5.6448 MHz
- cps3113: 1 x SC-Cut 6.144 MHz
- triodehunter: 1 x SC-cut 5.6448 MHz
- BDL: 1 x SC-Cut 5.6448 MHz
- wealas: 1 x SC-Cut 5.6448 MHz + 1 x SC-Cut 6.144 MHz
I am willing to change to 4x SC-Cut if that changes makes the order easier, but my preference would go to two of either.
Do you have any estimate of shipping times once the order is placed?
- hidjedewitje: 2x SC-Cut 11.2896 + 2x AT-Cut 11.2896 +2x colpits-clap pcb
- cerole: 2 x SC-Cut 45.1584 MHz + 2 x SC-Cut 49.1520 MHz, 4xTWTMC-DIL, 4X TWTMC-D, 4X TWTMC-OVN
- euro21: 1X SC-Cut 45.1584 MHz, 1X SC-Cut 49.1520 MHz, 2X TWTMC-D PCB, 2X TWTMC- OVN PCB
- Kazuo Ozawa: 2X SC-Cut 49.1520 MHz + 2X TWTMC-D + 2X TWTMC-OVN
- wealas: 1 x SC-Cut 5.6448 MHz + 1 x SC-Cut 6.144 MHz + 1 x SC-Cut 11.2896 MHz + 1 x SC-Cut 12.288 MHz
I updated my order. So when will we reach the 15 PCS MOQ per frequencies? I think it will be so long still... The GB list has opened already for long time ago.🙁
- gabor80: 1 x SC-Cut 5.6448 MHz + 1 x SC-Cut 6.144 MHz
You are right, the GB was opened long time ago and it's very difficult to understand when we will reach the MOQ.
I only can repeat what I said several times: the best phase noise performance are reached using crystals that have a frequency around 5MHz, overall if they are SC-Cut type. This is not my own opinion, this is the reality.
Phase noise means jitter in the time domain, so one should use oscillators with a frequency close to 5MHz to get the best performance in audio digital devices.
I'm working on a discrete DAC that will implement 2 oscillators at 6.144 MHz and 5.6448 MHz.
I believe that the interest will grow as soon as I will share the design.
Thanks, I hope the MOQ will be soon reached.😉
I use the 45/49 Mhz sc-cut oscillator without problem what I bought from you before. Audiophiler guys who I borrowed to test, amazed how well it sounds, over the commercial ones (NDK, Crystek etc.).😀
I love the tone and the precise bass of this crystals:hbeat:.
- Hellokitty123: 1 x SC-Cut 5.6448 MHz + 1 x SC-Cut 6.144 MHz + 1 x SC-Cut 45.1584 MHz + 1 x SC-Cut 49.1520 MHz + 2 x TWTMC-D + 2 x TWTMC-OVN
+ 2 x TWTMC-DIL
+ 2 x TWTMC-DIL
+ 2 x TWTMC-DIL
- canvas : 1 x SC-Cut 5.6448 MHz + 1 x SC-Cut 6.144 MHz
Added myself with one freq more, let´s see if this time we get to the mq
- lindamar: 1 x SC-Cut 5.6448 MHz + 1 x SC-Cut 6.144 MHz
+ 2 x TWTMC-DIL
