Hello!!, what is the best way to go with the zen v4, monoblocks or stereo? Can I play this using my receiver like pre?
If I love steel work, I might build the mono blocks. Otherwise, I would go for the stereo as my experience confirms no difference in sound quality between them. If possible, I might build a bit over-sized stereo block for a flexibility in case I further go for upgrade-tour.porfi4ever said:
JH
Monoblocks usually allow for more heat sinking per
channel, and that's what you want.
Also, no problem with receiver pre.
Nelson Pass said:
heat sinking per channel
Your comment immediately reminds me of 100W dissipation required per channel with 2A bias. (65W dissipation with 1.3A bias). Yea... it IS hot ... and your comment IS hot too ...
JH
Unbelievable
Thanks every one for reply to me, specially to "The One and Only" Mr. Pass for share your thoughts. It is unbelievable that I can talk to a genius like you. Thanks again.
