Fascinating - I'm becoming interested in OTL now - what are your thoughts about this design and that of Tim Mello (from 2010) ???
Thanks @Bigun - my apologies for my ignorance but : which design you are speaking about and who's Tim Mello ? 🤔
T
Joined 2009
Here’s a link.
https://audioxpress.com/article/your-can-diy-a-25w-otl-tube-amplifier
All this OTL stuff is quite new to me, eager to learn.
Ah, OK - I see - thanks !
Why not ? I would be worry though by the proximity of the 6C33C vs. the other parts, about temperature, and rather choose a larger chassis and/or a much more serious cooling (i.e. chimney effect around these power tubes, like I do on my U-OTL). In fact, those big 6C33C not only heat the air, but also generates much infra-red !
To give an idea, here's the temperature I took on the top of one of the 6080 on my U-OTL : 190°C at 5mn after starting :
T
T
Hi Tubelectron,
The thread popped up again, nice! I read a lot through it when you were building the amp, also a lot of proposed modifications and so on, so my question: can you post the latest schematics? Maybe even better if you could post it in the first post of the thread (ask a moderator)?
many thanks, Erik
many thanks, Erik
Got any real test data to shew us? Like THD & watts at clipping into a resistive load.I can speak about the original Futterman patent design - since I have made tests. 6080 Off-Specs will provide :
- increased distortion.
- reduced power output.
'It sounds OK' isn't much information for people a World away. with different speakers & on & on.👎
- Tubes / Valves
- The ultimate OTL6080
