Actually absolute phase might come into play depending almost entirely upon how you play, what your tone settings are and most importantly IF your sound includes a lot of real low end or "chunk" - the way the cone moves when you hit the strings is either going to be in or out.
Playing solo, or without anything other than bass &/or drums, this can be part of one's sound. It is for me. So I do try to set it up so that when I whapp" the strings it gives a pulse out to the audience... of course with other guitar and other instruments, the low stuff just muddies up the sound and gets in the way usually, so then it really makes little difference.
It might matter a bit if you are doing some "critical" recording - and you might notice a bit of diff in the total tonality of a given track depending on the absolute phase of the track, AND the absolute phase of the output of the rig (assuming you've been mic'd).
But otherwise, rather irrelevant, imho.
_-_-bear
_-_-bear
I know the website 😎
Here some more(with a lot of schematics!)
http://www.bnv-gz.de/~ooehmann/
http://tremolo.elektroda.net/tematykar.php?ver=pl&adres=Firmowe
http://www.drtube.com/index.htm
b_force said:
But if you at another tube, the signal will be Pi rad or 180 degrees out of phase.
It's normal, if you don't use 2 amps in parallel feeding them from the same source. Absolute phase between line out and microphone matters when miking; in case of an opposite polarity lows will be thinner.
