The Problems of Parallel
I kept an eye on both pairs but decided that I have enough iron on the shelves. The toroids were tempting though.
30W 350mA DC, 4*PL84 is almost a bit shy for those transformers. Wiring the output tubes as triodes would be a bit wasteful for such nice transformers, I bet you can get around 20W if you run them as pentodes. A healthy dose of local feedback (Schade or output plate to driver cathode) would trick the tubes into behaving as triodes but with pentode efficiency.
Less hassle with the Miller C too, a single high gm pentode (6E5P or similar) operating with a decent plate current could probably drive the whole thing just fine.
Reactions: OldHector
I would suggest the ECL 82 as driver; triode part Ra 220k,Rk 2k2, direct coupled with the cathode follower formed by the (triode connected) penthode part, Rk 22k (3W). The triode has the lowest distorsion of all triodes I've come across and sounds very pleasant.
