The Pass Pub: The High-End Off Topic Thread
Stafan,
I told you it could be tricky. You might be one of the few who gets it correct on the first try.
Token whites in a family of mostly Vietnamese don't often stand out, hence the test.
Cheers on your investigation skills. You seem to win every time I have these little quizzes.
Leave some for others would you?
EDITED
Reactions: 1 user
Official Court Jester
Joined 2003
Dunno Cal ......... to me - you look totally Vietnamese
Maybe we can't see that on pic, but we are blessed to know from jolly exchange through years - only difference between you and your smarter, better and more pretty half is - difference in beer amount per year
As is normal to be with any proper Man and his Life-Guide, Owner of Everything Rational
:clown:
Reactions: 1 users
The hunchback and the dwarf
At night in the cemetery, an ugly dwarf jumps in front of the hunchback and asks:
  • What's on your back?
  • A hump.
  • Do you need it?
  • No.
  • Then I'll take it off.
The hunchback suddenly straightens up, happily seeing that he is no longer crippled. He hurries home and meets the lame man. He tells him what happened. The lame man immediately rushes to the cemetery, looking for the miracle-working dwarf. The dwarf jumps there too.
  • What's on your back, you lame?
  • Nothing...
  • Then take it, here's a hump.
Joined 2011
Reactions: 1 user
Joined 2011
Yesterday evening I was restless, had baught a new saw and had a lot of waste mdf laying around. Made diffusers for the upper corners of the tqwt pipes. Can maybe work both as LF ”pipe-straighterers” and most of all HF diffusers for rear wall reflections. Noone remembers a coward :)
Reactions: 1 users
Joined 2003
in principle, Mighty Moi Personally - I'm interested only in amps of lower power and simpler construction ....... well, not necessary simpler but necessary simple signal path
but, technically- as food for brain, every amp is interesting to take a look at, or proper stare
just one comment - I did ggle and saw pictures - just one simple comment to show my lazy disgust - with heatsink of that size, 125W amp, and twice that!! - only if it is in D Class
if it is D Class - I don't care to see inside
if it is any other Class - it's ooking disgrace and insult of potential buyer intelligence
https://www.stereotimes.com/post/job-225-amplifier/
note: even if product is possibly that (disgrace and ... ) it still can be interesting to see schm of; example - Glorious MF A1, real Jewel and product of Tim de P. originality, but produced as worst scam - having longevity of little bigger box of matches
so , dig schm and post somewhere, you're welcome to :clown:
