Should give some light relief to the various 'agencies' who monitor us so closely. Good job that we have one-time codes!!! 😉
You forgot to put in you code number Brian!!!
18984
Used a scratch code ... as you clearly realized by your use of an emoticon!
"They" are watching all of the time so - as you know, just because I am paranoid dosent mean that they are not watching me.
"They" are watching all of the time so - as you know, just because I am paranoid doesn't mean that they are not watching me.
"They" may not be the one's watching us that you think they are... 😱😱😱
and counting...
This thread does an average of 8 posts a day, odds look favorable that you'll be hitting 25000 yourself before this thread count does.
#19000
Yea mighty transformer relic,
is it possible for an EI-66 core to do 90VA ?
(turns out our little 350Vac mains mishap in december also blew up the primaries of the electric motor adjustment of our bed)
"This began, most recognizably, with the rejection of politically oriented thinking as essentially a hopeless waste of intellectual effort.
RIP John F. Nash:
John Forbes Nash, Jr. - Wikipedia, the free encyclopedia.
I'm hopeless, because those "hopeless waste of intellectual effort" determine daily- and future life of ours.
RIP John F. Nash:
damn Dutchie Srbijanac
(width/3 x height of stack x 0.9)^2 =VA of core ; [cm] , [VA]
if it's little on wimpy side , slightly higher Us will compensate for core lossesssssesss , considering intermittent usage
Taking 15% regulation off, still remains 78VA.
(one transformer was saved by the slow blow 630mA fuse soldered inbetween the 2x115Vac primaries, rectified cap juice is 29Vdc)
Things weigh 835 gram, would beat the weight/VA factor of a toroidal.
Similar 66x55 sized ones I can find, don't go higher than 50VA
(35mm blech thickness, original ones do 30mm).
I could saw through the spot welds on both sides of the core, rewind the sheits, and weld the iron again.
- The Pass Pub: The High-End Off Topic Thread
