so, related to my question a while ago about the angled aluminum.. I finally found some that I like and cut it to size. I'm needing to layout the holes for the devices, 16 TO-220s. They are PCB mount and I have a flange on the PCB that has holes for the devices. I started thinking though, is there any reason not to tap the aluminum angle itself, then secure the devices using a socket head screw into these tapped holes, then just secure the PCB to the underside of the angle bracket via a nut? For some reason I've always just drilled a hole without threading, but it seems that this might work better, no?
Also, I'd like to try the Kapton tape approach this time, for no reason other than to do something different. Any good sources and recommendations on parameters (thickness, type, etc.)? The angle bracket is 1" x 2" by 0.188" thick and the 1" side is where the devices will be located. I'm assuming this (Kapton tape) is what Papa uses, as the pics on the First Watt the isolators look torn off a larger piece. In this case, I'll need to use thermal grease on both sides of the tape, right?
First Watt uses mica insulators and Thermalloy grease
exclusively. I have never tried Kapton.
Well...... .If you have a single ended chassis, ie all the same output devices, or if you have a bunch of matched output devices then you will like this:
www.diyaudio.com/articles/burning-amplifier-1
The FIRST Burning Amp, the BA1
Enjoy!!! And thank Nelson!!! 😉
Discussion thread here:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=142055
We decided that we can't hold it back any longer - time to get someone building!!
Mark
Mark
The Burning Amp Article is now corrected. Reading it should be easier now! Same location
Speaking of Burning Amp.. The Burning Amp Festival will be October 18th, 2009 at the same location as last year. It is a Sunday..
New Burning Amp Fest Date ?? ... October 18th 2009 ?? ... should we keep looking for follow up news at http://www.diyaudio.com/forums/showthread.php?s=&postid=1808903#post1808903 ...??? ... And when are the burning amp web pages going to be updated ????
Count me in ... again 😉
Hey FastEddy,
Keep checking the same thread that you mentioned. We will eventually split it into a 2009 thread , but not for a while.
The economy has all of us pretty busy, and poor too!, so things like the website might not get much attention for a while.
For the same reason, we will need a lot of people to sign up in advance to pay the rental and other expenses, so if you know that you are going PLEASE SIGN UP !! Well not yet , because we don't have a sign-up list yet.. 😀
Mark
Mark
Zen Mod said:
nada
I just re-sent 2 mails.
Magura🙂
EDIT: Your Neobee account refuses to accept mails.
EDIT2: Sent to your Nadlanu account as well now.
Magura🙂
luckily - this is off topic thread ........
Yeah, we ought to get Variac in the bin for his amp talk here
Magura 🙂
Magura 🙂
uff , couldn't find bearded one .....
- The Pass Pub: The High-End Off Topic Thread
