I posted this question to an ancient Lepai T-amp thread, but better to start a new thread I suppose.
I want to add a "clip" (not "fault") LED to the LP2020, but have not found an actual circuit. Has anybody done it? What is not clear to me is whether the OVERLOADB pin on the TA2020 goes high when there is no fault, or does it float? The chip's doc only says that it is "5V logic" and goes low when there is an overload. If it normally goes high, I'm thinking of a circuit like this:
OVERLOADB -> 5K resistor -> base of an NPN bipolar transistor. The Emitter to ground. The collector to the positive end of one of the diodes that lights up the volume knob, between the LED and the resistor the supplies it with power. (Can also replace the LED with a red one. And can also add more resistance to that supply line to reduce the LED current somewhat.)
The idea is that normally (when there is no overload) the transistor will be driven to conduct and bypass the LED so it will not light up. But that depends on that OVERLOADB pin going high normally. If that's not the case then a more complicated circuit would be needed. If that pin is an open collector, can it take 12V when open-circuit?
