The "not so lowly" TL431
Interesting, in the current issue of "SwitchingPower" magazine, Dr. Riddley has a lengthy article on the popular and cheap (not inexpensive, cheap !!!) TL431 adjustable reference. The conclusion is that it will work quite well as an error amplifier cum reference (and a good low noise reference at that.) Riddley suggests several compensation methods which will result in very good performance.
These parts cost about a dime apiece !
This is no great secret - the TL431 (and its earlier incarnation, the TL430) have been used as error amp/references by the power supply industry for over 20 years. Hardly anyone uses them for their original intended application.
There is an elegant design for a soft-start circuit using the TL431 as the only active element in the latest AudioXpress magazine. When the input voltage via an RC exceeds the reference voltage, the output pulls down a relay to ground.
It's also in the TL431 datasheet, Fig. 27.
