STK350-030 SONY
STK401-040
STK402-020
STK402-040 SHARP/JVC
STK402-050 JVC
STK402-070 N CHICO
STK402-070 S GRANDE
STK402-071
STK402-090
STK402-100 SONY
STK402-120 SONY
STK4048 II
STK405-050
STK405-070
STK405-090
STK405-110
STK405-120
STK407-040
STK407-050
STK407-070
STK407-090
STK407-100
STK407-120
STK407-240 LG
STK408-040 SONY
STK410-030 KENWOOD
STK411-210
STK411-220
STK411-230 SONY/ KENWOOD
STK411-240
STK411-290 JVC
STK411-550 SONY
STK412-000 SONY/JVC
STK412-010 JVC
STK412-020 SONY
STK412-040 SONY
STK412-150 SONY
STK412-170 SONY
STK442-110 LG
STK442-120 SONY
STK442-130 SONY
STK470-010 PANASONIC
STK470-020 PANASONIC
STK470-040 PANASONIC
STK470-050 PANASONIC
STK488-010 SHARP
STK488-050
STK490-040 AIWA
STK490-070 AIWA
STK490-110 AIWA
STK490-310 AIWA
STK490-340 AIWA
I DONT HAVE A INFORMATION ON THEM !!!!! what goin on???😕
STK401-040
STK402-020
STK402-050 JVC
STK402-070 N CHICO
STK402-070 S GRANDE
STK402-071
STK402-090
STK402-100 SONY
STK402-120 SONY
STK4048 II
STK405-050
STK405-070
STK405-090
STK405-110
STK405-120
STK407-040
STK407-050
STK407-070
STK407-090
STK407-100
STK407-120
STK407-240 LG
STK408-040 SONY
STK410-030 KENWOOD
STK411-210
STK411-220
STK411-240
STK411-290 JVC
STK411-550 SONY
STK412-000 SONY/JVC
STK412-010 JVC
STK412-020 SONY
STK412-040 SONY
STK412-150 SONY
STK412-170 SONY
STK442-110 LG
STK442-120 SONY
STK442-130 SONY
STK488-010 SHARP
STK488-050
STK490-040 AIWA
STK490-070 AIWA
STK490-110 AIWA
STK490-310 AIWA
STK490-340 AIWA
YOU MUST BE JOKING! 😀
I have some of the ICs so I know I got the pdf from Googling.
In front of me is an STK405 chip and the pdf
Half of them is here: http://www.datadart.com/al/sanyo/ (took me about 30 seconds in Google)
... and if you don't find information on some, it's probably a good indication they're not available anyway ...
Dirk
Dirk
I'm still looking, but has anybody found the datasheet for STK040-071?
I have the chip, but not the datasheet!
I figured out from a table found on another datasheet that the -070 is 60-ish watts, and I'm going to call it close enough to that for me, since the -xx1 variants seem to be simlarly-rated for power output to the -xx0 versions.
Of course, the proof is in the pudding and I will have to measure it directly when the whole thing is all completed...
I am still looking for most of these Datasheets. Beginning to wonder if some of them exist or not.
STK410 Series can not be found anywhere
Bridged
So, for any bridged output you need to have double the normal output in ohms. Example if the output in ohm is 8, for the same setup for bridged in would have to be 16 ohms for the same amp?
If you have speakers with more than 12 Ohm. 😉
Yes, because each half of the bridge only sees half the impedance. A bridged 16 Ohm load appears as 8 Ohm for each half of the bridges.
If you want to use lower impedance, you need to put two bridged amps in parallel or use lower supply voltage which leads to lower output power.
I just want to point out that this chips have long been discontinued by the original manufacturers ( Toshiba, Sony, Aiwa etc ) and what you can find on the market now are ic's ,,made in China" or , if you're lucky , NOS ic's . That's why in some cases it's hard to find a datasheet .
- Chip Amps
- The NEW STK chips
