{ THE IMPULSER • V 1.2 • SINGLE IMPULSE AUDIO GENERATOR }
The Impulser is a single impulse audio generator, the impulse is about 1 KHz - 1.40 Vrms @ 600Ohm, (SINE - SQUARE - SAW- TRIANGLE) before and after the impulse is present a 'silence' about 0.5 seconds.
THE IMPULSER DOWNLOAD
The Impulser Update V1.3
{ THE IMPULSER • V 1.4 • SINGLE IMPULSE AUDIO GENERATOR }
UPDATE 1.4 - THE IMPULSER V1.4
like this :xstreme
Which your program works like this?
Put a Load Res to output of your amplifier (R) and measure the response to point A and B with your scope, then verify if you have amplifier with high internal (bottom trace) or low internal (top trace)
obviously the amplifier input must be driven with The Impulser
The Impulser V1.64 Update - Fixed all output signal to 600 Ohm @ 1.228 Vrms
THE IMPULSER - BONISAUDIO
The impulser V1.68
THE IMPULSER - WWW.BONISAUDIO.COM
Added a GAIN TEST...
- Design & Build
- Software Tools
- The Impulser • V 1.0
