The "Force 8" collaborative design
The “Force 8” speaker design project
I’m starting this thread as a design exercise – a virtual design, aka a thought experiment. I’ve been thinking about it for some time, and I hope that it reaches fruition in a physical DIY design. Should it make it that far, then it will be my wish that the plans and specs will be shared amongst the audio DIY community.
What is the “Force 8” project? Well, the Beaufort wind scale describes a force 8 as a “fresh gale”. My aim is to create a modern 3-way design, paying visual and performance homage to the Gale GS401a. (Hifi enthusiasts of a certain age may now begin to reawaken longings, mentally drool, etc.)
Yes folks, the plan is to design a speaker that visually evokes the silver end-capped “amp-killer” that was the stuff of dreams for many of us.
In any design process there have to be some rules, and so here they are:
THE RULES
1. This is NOT a cloning exercise. The speaker will use new, currently-available drivers, not vintage units or NOS (new old stock).
2. The speaker will maintain the L:W😀 aspect ratio of the original GS401a, and will be sized somewhere from original actual size to 115% of original. (I figure that extra internal volume will permit some extra scope for driver selection, without overly compromising the object of “visual homage”.
3. The design will be a sealed cabinet.
4. The complement of drivers will be the same: two 8” bass drivers, a 4”-ish single mid-range and a single tweeter. (I’ve given thought to using a modern full range paired with a super-tweeter, but that will be a topic for further debate.)
5. For maximum flexibility in driver selection, the speaker will be tri-amped. Similarly, it is my suggestion that a miniDSP be used in preference to a XO. (In the fullness of time it may be that a suitable XO can be developed, but for the moment, we’ll use a miniDSP (or similar). That will facilitate the sharing of different approaches to crossing between driver units.) Drivers of any impedance may be suggested. Bass & midrange should be cones and the treble should be “visually similar” to the original treble unit, & all are to be flush-mounted on the baffle.
6. The speakers will play as low as the original GS401a’s and as high as the original GS401a’s. Watts are now cheap, so the overall sensitivity is perhaps less critical, but let’s agree that the speakers should be aiming to recreate (at the least) the frequency range & SPL that the originals could muster.
7. The arrangement of the drivers on the baffle will maintain (as neas as possible) the original spatial relationship (to maintain the “visual homage”).
8. There will be end caps. I’ve had some thoughts about this feature, and I have a “cunning plan” – but more of that later. The end caps will be a cosmetic feature and may be chromed metal, painted (two-packed?), or wood-grain. My concept is that they should be removable, perhaps upgradeable? (More about this topic later. It is not essential to the driver and cabinet design.)
9. The GS401a’s’ cabinets featured an 18mm proprietary 3-layer material. For simplicity’s sake, I’ll specify void-free 18mm ply. (Please DO NOT chime in to ignite a flame war about MDF, etc.!)
10. The GS401a’s cabinet had an internal brace. The force 8 design will feature two “holey braces” (nod to Planet10), one behind each bass driver.
11. The GS401a’s were designed as stand-mounters. The Force 8’s performance should mirror the placement options of the GS401a.
12. To borrow a term from engine-building I propose that contributors submit ideas and comments in 3 categories:
Phase I – True DIY “frugal-phile”, making the best of drivers and materials of limited cost, to achieve a nevertheless pleasing performance;
Phase II – Where I anticipate most effort will be made, using drivers and components readily available and reasonably priced. Nothing exotic.
Phase III – Cost-no-object. Go hard – exotic drivers, yak belly fluff stuffing (cryogenically-treated, of course), silver wiring, etc. - but don’t expect to have lots of company.
13. The final rule is that I want to make it clear that I don’t want contributions telling me I need to use 6” or 10” woofers, one woofer instead of two, a vented cabinet, or any other fundamental change to the approach. Find your own sandpit. (Any such suggestions will be referred back to this rule.)
I have done a considerable amount of research on the GS401a and I will be posting links to web resources, the Gale Yahoo Group, etc.
I live in Brisbane, Australia (no, not Austria!) and it would be great if some local DIY enthusiasts joined the endeavour – but hey … everyone is welcome. Bring your friends.
cheers
Doug
Internal volume calculation:
((605-36) x (330-36) x (270-36) /1000000 = 39.14L
This is inclusive of the space occupied by the internal brace(s) and the mid-range enclosure.
So let's say that the two woofers "see" 37L. (If we allow an extra 15% as discussed in post #1: 42.5L)
cheers
Doug
The GS401 is a W-MT-W 1978 speaker. Awards
The Sony SS AR1 TM-WW is a 2011 speaker. Awards
A great exercise would be to compare the two designs using the same drivers. How much sound quality do you give up for style?
"1978 style layout" versus "2012 performance layout"
Hi Linesource
Inherent in my project is the acceptance that the "GS401a arrangement" will have ultimate physical limitations. I accept those. The challenge is to revisit the limitations of the physical format, utilising modern knowledge and drivers, etc. to extract the best performance whilst keeping the style (/WAF).
cheers
Doug
One last pitch for 2014 tech in the 1978 GS401 cabinet .... two 10" woofers, plus the 90H x 40V polar pattern SEOS12 waveguide with a 1" compression driver centered above. Xover at 1000Hz with LR4. This will provide decent controlled directivity, plus decent bass with help from MiniDSP equalization. As a bonus, you can get ~94db/watt efficiency from two 10" woofers wired in parallel.
There are several well reviewed high-efficiency Studio Monitors which use dual 12" woofers plus a waveguide/horn centered above them. GREAT DYNAMICS! After reading a couple reviews, you might consider building a slightly larger cabinet with the same aspect ratios as the GS401. MiniDSP equalization + WATTs = deep_bass in a small box.
Hi Linesource
From your link the -3dB point at the low end is in the 50s which is reasonable but the small volume will mean less efficient drivers. Is a 5" midrange within the rules or must it be a 4"? The larger midrange is likely to help widen the choice of suitable woofers.
The Gale woofer to mid crossover is at 475Hz which is quite high but probably appropriate for a small midrange. Do the rules require it to be kept?
The crossover from mid to the tweeter is at 5kHz! If this is to be kept then we can forget a 5" midrange but we can use pretty much any tweeter. This crossover point is going to influence the sound.
Are metal drivers and/or phase plugs within the rules?
Just off the top of my head:
SB Acoustics SB23NRX45-8 x 2
BMS 5S117
Monacor DT300 + waveguide.
I'd move the xover points to about 250-300Hz and 2.5k.
The SB 8" woofers want twice the volume available. It looks too much of a squeeze given the Gales had tight bass and more bass extension.
I also would lean towards a 5" midrange but not if the original crossover frequencies are to be kept. Is the 475 Hz - 5 kHz for the midrange an important part of the character of the Gale? It will certainly influence the sound.
Is a waveguide in the spirit of the original speaker?
Plugged into a box calculator the SB woofer gives a F3 of 51Hz in a sealed 19L cab albeit with a Q of 1 and a 1.28dB peak somewhere.
I get an F3 of more like 70 Hz and a Q or 0.91 that would come down with a bit of stuffing. I get an F3 of 51 Hz in a full sized box of 80 litres for 2 drivers. One of us is having finger trouble. I must confess I am too tired to check tonight.
If a waveguide is in the spirit of the original would depend on the OP. I wouldn't use a tweeter without these days.
Perhaps but that is to do with sound quality rather than homage to the Gale?
I disagree with the op concerning the active crossover. The 4 ohm load requiring a big beefy amp was very much part of the Gale legend.
I get pretty much the same result using another calculator (WinISD this time) as before: F3 around 51-53Hz in a 19L cab (or 38L for two of them), system Q of 0.92.
I got the impression that the OP wants to follow the form factor more than being historically accurate as such I have no issues with active crossovers or waveguides.
If this was my project I would insist on both but it isn't so we may have to wait for the OP to comment.
Hi Andy19191
I'm amenable to suggestions for any drivers of the same type that fit within a cabinet of the same aspect ratio, allowing a +15% volume tolerance.
It's only sensible that I'm not wed to the exact GS401a XO points, as these will be ruled by the characteristics of each driver.
I'll consider a 5" mid if it can fit (including its separate chamber).
WAF is a criteria, so if the metal drivers and phase plugs don't inhibit fitting a grille cloth in the style of the original, then fine.
cheers
Doug
Bzzzt! Rule 13.
I'll entertain up to a 15% increase in cabinet volume.
cheers
Doug
Hi Charles Darwin
Active XO's and waveguides are in for consideration. See post #16.
cheers
Doug
I see no point in recreating acknowledged "difficulties", so no, I'm not setting out to design a speaker that's deliberately a difficult load. I suggested triamping as a way to avoid such difficulties. Much later down the track someone may wish to design a 3-way XO for the drivers eventually selected.
cheers
Doug
I always admired the Gale GS401 and it's variants. It took me years to understand what was special about it, despite the horrible low impedance.
You see, what is odd about doubling up the drivers in a three way is that the sound pressure from doubled drive units doesn't fall off as inverse square of distance, it is actually merely inverse distance. It is because the waves are cylindrical.
Which means the people at the back hear it much louder. 😎
PA designers have always understood this. In fact stacked 4 drivers work even better for the people at the back.
The Gale happened to have a lightning fast mid driver too which is always good.
But really Troels Gravesen has designed a near ideal three way here: 3-Way Classic
Double it up to a vertical WMTTMW design, preferably in series to keep impedance up, and you really have something. :spin:
