I am off to bed and it's been a good day, but AllenB just did something that has made me livid!
I bought the lumber, and started cutting the boards for my Hamlet center this afternoon. I went with HDF panel boards like I did with my Elsinore's for two reasons, by laminating them together I get the correct thicknesses, and it's so much easier to work with if your by yourself. Not to mention, it's true HDF, maybe even better since I'm laminating panels together. I'll take pictures when I have something to take a picture of...I just ripped two pieces.
Clausen,
Where did you find the HDF? What are the dimensions (thickness?) of the individual HDF sheets? How difficult is it to work with? What are the advantages over laminating 3/4" hardwood plywood with 1/4" hardwood plywood to form the 1" thick panels?
Thanks,
Happy Jack
(I just received the rest of the drivers so it's time to start on the boxes!!)
Joe,
I sign up for eight Purifi drivers.
I want to build a third pair of Elsinore 🙂
Give that man a prize! A new World Record!
Now I can go to bed with a smile, saved by the bell. 😀😀😀
Purifi driver mentioned has it's price 1882 DKK ~ 292 USD is equivalent to Satori MW16TX-8 which is 298 USD but lower sensitivity
Wow the Purifi version is going to be expensive (2400 plus shipping/tax for just the 8 drivers). You have to ask, if the Elsinores are as good as has been eye witnessed, how much can you expect from a different driver set? Seems to me you'd be chasing an illusion. But there's no limit to what someone might spend in search of the ultimate.
That said, if I didn't already have all the parts and xovers built I bet I'd move in that direction. I suppose the xovers would all be different going from the MFC to the Purifi.
I am going to send an email to Purifi. It looks like that we may order 8 x 2 pairs = 16 drivers. One set for me and the other for an Aussie who will make himself known.
In the email, can I get a hands up and tell them what kind of number in the near to medium future, that they get an idea of the interest. I would love them to take an active interest in the development of "Purified Elsinores" and let's be honest we do live in a numbers world.
Hand up those interested in putting together pairs/sets (8). We can arrange something from Purifi and we all order from them rather than any middleman.
I won't send the email until then. Remember that you will be dealing with them directly. They will know that they are for "Purified Elsinores" when you order in a lot of eight.
What will be the difference in box design?
It will be minimal, below shows the changes.
Driver Outside Diameter: 174mm -> 178mm
Recess: 7mm -> 5mm
Actual Inside Hole: 146mm -> same
So the inner hole is the same, the outer diameter is fractionally larger and the recess is smaller.
The port is yet to be determined, but it may be a bit shorter.
Cheers, Joe
Will the xovers change?
Clausen,
Thanks,
Happy Jack
Home Depot sells it in 3/16" and 1/8" PANELS. For some reason the 3/16 is twice as much even though it's not twice as thick. 🙂 So I bought 2- 4'x8'x 3/16" panels and 1-4'X8' x1/8" panel. I need 4 3/16" panels to make 18mm, and 4 3/16 and 2 1/8 inch to make 25mm or one inch. (For some reason it comes out about 1/16 less than an inch.)
I ripped the 4"X8" panel not quite in half, approx 24 3/4" X 23 1/8" I need 6 panels per side for each 1" section. So far I have cut 10- 15.5" X 24 3/4" and 12- 9 3/8" X 24 3/4" panels. Once everything is cut, I'll start laminating and then cut to the correct sizes. So I've rough cut everything a little bigger and I'll clean up my edges once it's all laminated together. I used Titebond II before and it worked fantastic.
It's super easy to work with in these thin panels, but it's also not that hard to trim because there all smaller 1 inch pieces, nothing will be longer than 24 3/4" once I get to trimming it all down. I ripped down these 3 pieces, and leaned them against a folding table in my garage, and it started to tip it over, I had to grab the table and panels. The stuff is super heavy and dense. (I have a a much better table saw than when i built the Elsinores too, so that helps. But even with my ancient Craftsman I had very little trouble. https://www.skil.com/wormdrive-table-saw-spt99-11/)
It is extra work gluing everything together, but once it's glued you just wait.
Here's the math to do ONE Hamlet, since I'm just doing the one for a center now.
For the front 18MM/3/4" you need 4- 3/16" panels. For the front and back 25MM/1inch, you need 4- 3/16 each and 2- 1/8" for the sides, and top same, 4- 3/16" and 2-1/8" for the sides you need 6 each side, 4-3/16" and 2-1/8". I screwed up on the front and back panels. I thought I could get 10, 9 3/8" X 24 3/4" panels from one 96" panel, which i might have been able to do, but I had to rip it in half because I was by myself, but 10 cuts with 1/8" blade is and inch and a quarter. But that's okay, because I'm going to have more than enough from the last section of 1/8"X 23" X 96" panel I'll have left after all the other cuts.
The Elsinore's are something like 45" tall, so keep that in mind. And the 1/8" panels are a better deal because two are less than one 3/16" panel or about the same, and 2 1/8" panel is 1/4 ". Now that I think about it, maybe I would have been better off getting all 1/8 panels, but I did all this math a while back and took notes, and bought what I had in my notes.
Hope that helps. If you build them this way, you'll need a hand truck to get them inside or help for sure. I took mine inside with a hand truck and THEN, put the drivers in them because of how heavy they are with NO drivers.
Clausen,
Thanks,
Happy Jack
Sorry, It's a lot to comment on so I missed this part...so for me it's just the math and the cost. You cannot get 1" anything, and to get 3/4" whatever, it's expensive. The combination of 3/4" with anything, to make 1" there's just nothing out there, and the combinations are very expensive. For example, you cannot get full sheets of a lot of materials, and they just don't add up to what you need for the Hamlets or Elsinore's. For example, two 3/4 inch panels for the front baffle/brace is 1 1/2". But the specs calls for 1 3/4". So yeah, it's more complicated, but to me this was easier...
That stuff costs a fortune, a quick search suggested €700/sqm. Can panzerholz be obtained more cheaply, and can you even use ordinary saw blades and router bits?
This is amazing stuff ! But unless you own your own woodwork shop - you will be charged a fortune to have your cabinets done - Aluminium works out cheaper. I watched a build of a high end speaker on a German forum and the workshop equipment they had was incredible. In a perfect world we might all love this to do our cabinets - in Australia I am not sure you could find someone to do the job. After seeing that build I did some inquiries and examined a piece - meant as a piano part. Germany is the place to get that done and shipped out .That build was from memory ? $40000
Anyway I think Helmut is on the right track -for mere mortals in other lands lead lining a cabinet can bring similar benefits
In Australia you have high quality void free marine plywood?
AFAIK good quality marine ply is also very dense and rigid. And tough on the tools...
good plywood is not necessarily dense. Dense is not an asset you are looking for. Light & stiff. is better than heavy at the same stiffness.
dave
dave
Would you consider baltic birch that lightweight stiff option?
Baltic Birch is a goto… there are different quality. As the BB we were getting was declining in quality (China? Russia?) we switched to Murphy ply, which uses quality baltic cores, QCs and adds an extra pair of veneer layers. Essentially high quality BB.
The best ply we have used is staranded (same as fossilized) bamboo plywood. It is really dense, but it is a side effect of really incredible stiffness.
dave
dave
Everything moves. If it is higher mass due to higher density it moves at a lower frequency, easier to excite so not as good as a sma estiffness box wall that weighs less and will move at higher frequencies which are harder to excite.
dave
dave
The thing about something dense (heavy) is that it doesn't want to change. If it is still it is hard to get moving and if it is moving, it is hard to stop.The nice thing about something very dense is that it doesn't want to move.
I think he means that it opposes the motion of the driver itself.. (and as long as the coupling is very rigid to driver's basket: it can improve subjective clarity.)
Of course where you have very little force being generated (as with a tweeter), a lossy coupling is best to void transmission to the tweeter from panel resonances; so most of the time opposing driver motion is something to look at with respect to woofers (..and sometimes midranges).
- The "Elsinore Project" Thread
