Hi all.
I notice this question has been asked before, 4 years ago and still hasn't had a reply:
http://www.diyaudio.com/forums/optics/120388-long-throw-zoom-lens-attachment.html
So I thought I'd ask a similar question to see if there is anybody out there...
I recently bought a projector that will remain un-named as it has got a lot of bad reviews (Abus HD-12 Pro) which I actually like, except for the racket of the fan. and its inability to decrease image size except by moving the projector back and forth.
Yes, I should've bought a more expensive one, but my redundancy package wouldn't go that far..
All I want to do is move the thing back about a metre (into a convenient cupboard with a window - which I have yet to cut out, but keep the projected size the same. Long throw lenses are over £1000 which is a bit harsh as the projector cost less than £200. It uses a 5 inch LCD screen and all I can tell you about the lens is that it has a 68mm diameter at the front - I haven't found any info on focal lengths etc. on the web to date.
I have the projector 3.18m from the wall which gives a projection size of 100 inches (2.54 metres) diagonal. I want to move it back to 4.16 metres and keep the 100 inch projection size, the size would be 130 inches (3.3 metres) diagonal at that distance.
Not knowing a thing about lenses, is there anything in the Optics Shed that I could fit on the front or the back of the existing lens that won't put my mortgage payments in jeopardy? Could I alter the existing lens with a hacksaw, hammer and Duct tape? Would a chat with a friendly optician (if I find one) help?
Is there distances inside the projector I need to measure to help someone come up with a solution? Will a picture help? Is the Earth flat? Will I ever get another job that'll pay for a long throw lens?
Any (polite) suggestions would be appreciated.
All the best,
Fitch.
All the best,
Fitch.
Interesting question, but this part of the forum gets so little traffic, you know.
As a projectionist myself, I know that longer lenses - within reason - are easier than short ones. Fortunately for me, I can just pick what I need off the shelf.
I wonder if you couldn't play a bit with multiplier lenses meant for cameras? They can be found online for reasonable prices, or maybe you know someone who can lend you one?
I do actually have a x2 converter for my canon SLR, of course it's only a 50mm lens so I presume I would be looking for something a tad wider. Is that the sort of thing you mean?
Yes, the 1.5X or 2X converters. It's worth a shot if you can find a 68mm or larger. Or just test the one you have.
Which way?
OK. Do I put the converter in front of the projector, or do I put it between the LCD ands the lens,.
Which way round do I put the converter?
Sorry, but I'm quite hopeless at this sort of thing..
Put it at the front of the lens. Put the ring thread toward the lens, just as you would with a camera. Let us know what you find!
Oops!
Just got the converter out of the bag, only to find the rear cap is stuck solid. Even tried unscrewing it with a jam jar opener. Won't budge. Will have to take it to a workshop and try to prize it off, so will be a few days before I can answer.
Cheers!
Fitch.
Cheers!
Fitch.
I'm going to break the damn thing if I try any more. Will take it to the physics department in the University where they can mount it in a chuck and use a strap wrench on it, problem is, I've gone down with the dreaded lurgy, so am tucked up in bed for the next few days.
Ah, sorry to hear that! There's lot's of coughing and hacking going on 'round here, hope I don't catch what you got. 🙁
Get well soon, good luck with the test. I don't have a doubler myself, or I'd give it a try. Projectors I have no lack of.
well, basically, you would just have to attach a bi-convex lens to you projector ...
but ...
it would have to be calculated through, i'm talking of: focal lengths, diameter, distance to the projector ... also, a single bi-convex gives terrible errors, so an achromat lens would be the least thing to do ... but, honestly - i really do not have the time to calculate that thing right now, as i'm approaching my final exams here ... sorry 🙁
still, if you are lucky, the achromat lens which comes out after that calculation may be a standartised one, so you can buy it for less than 100 bucks from companies like qioptiq; you would only have to attach it somehow in the right distance and being aligned to the optical axis 😀
again, sorry for giving such an unsatisfying answer, i wish i could have helped you more 🙁
but ...
- General Interest
- Everything Else
- The Moving Image
- Optics
- The dreaded long throw question
