The diyAudio Firstwatt F6
Well, here I go...
I haven't visited these forums for several years, but I've accumulated the parts for an F6 and if I can muster my few remaining brain cells, I'm embarking on my first amp build beyond a few gainclones and a Bottlehead kit.
Wish me luck if you will...
.7
I was just set to buy a couple of Fluke Meters and now another option!!!
Can anyone advise a non-electronics based mindset which Fluke meters are best for building and testing the Pass Amps?
And, recommend any of the Kiethley DMM's to buy instead of the Fluke if this is a better option?
Two Flukes or one Kiethley to start the new lab I'm being 'forced' to build as well as any info on the new oscilloscopes that may be best.
Thanks,
P { margin-bottom: 0.08in; } Holzarbeiter
If you just want to measure dc offset and bias just buy cheap multimeters and with the money saved buy a nice quality lab power supply with 2 x bipolar outputs with current limiting adjustment.
After that get an oscilloscope and signal generator.
After that upgrade to better quality multimeters. You can still use the cheap ones for most things.
After that a distortion analyzer.
Maybe over a 5 year period. Just a bit at a time.
2 picoDumbs, 6L6, ZM - thanks a million for the guidance along the way.
Not bad considering I discovered diyaudio just 6 weeks ago and have never build an electronic component of any kind before this and the ACA.
glued to my seat. I owned a DartZeel 108 about 2 years, this F6 is giving me the same kind of finesse. I have yet to boost the bias from 1 to 1.3A, and caps are not close to being broken in. I am noticing the bias drifting around quite a bit, I guess this is due to the whole starving 9.1V zener diode discussion...
