The DiaPhone headphone amplifier
This is a simple little amplifier i just came up with, its based onthe so called diamond buffer, or atleast i think it is.
The primary application is driving headphones but simulations show its also capable of driving a 8 ohm load to a few watts of power.
A sim of a few different impedances:
http://i.imgur.com/tepDj.png
http://i.imgur.com/aS12Z.png
http://i.imgur.com/28mbq.png
http://i.imgur.com/i7K2b.png
If this has already been done, i apologize and will take these schematics down if so is desired.
Ok thats weird, a 1.5µF capacitgor across the output actually helps reduce/remove the oscillations to the point where it appears like what remains is the switching noise from the DC/DC converter i use to run off battery power.
It's not a diamond buffer, but that's ok. See the article by Walt Jung. It looks to me like a push pull emitter follower driving an output push pull emitter follower pair.
It surely is a diamond buffer. Maybe needs slight adjustments so it can perform as good as it should.
The THD figures are dissapointingly high for such a circuit but maybe thats because of the opamp model.
