The construction of a multicell horn
Hi Petter,
Thank you very much for this outstanding "tutorial" on building a multicellular horn. Are you familiar with "Chela Audio"? CH Audio Design He also constructs outstanding looking 15 cell cellular horns. Just curious...judging from his photos, is your build method similar to his? In other words, are there different build methods to cellular horns? Thanks again.
The spreadsheet contains all the info you need to build the horns, including the horn throat. I'm pretty sure I have it still at work, so I won't be able to check until tomorrow.
I plotted the data and created an Illustrator file with the shape of the horn cell walls so I could use it for a router template. I should still have that too. In fact this is probably better than the spreadsheet because I've done the work for you 😉
Hello, i Just read your topic about your multicell horns , impressive !
If someone can send me this famous file to build one, it would be very helpfull!
We have the project to make two of those for a Sound System and load them with Beyma neo 745pb and use them between 1,5kHz and 10kHz , do you think that would fit?
Thank you for your attention!
You can give me an answer directly on my Mail adress : dubproduct@gmail.com
Martin
Spredsheet
Hello there in hornland,
- I was impressed, when I stepped into this tread. With the help of a friendly forum member I got the spreadsheet and I am happy to resend it to other enthusiasts. It would be fine to see here some photos of people who did make copies....
Cheers, Hajo
