Ah, good point. Yes you understand me correctly. Will put another 2134 to use as a buffer. Should I parallel that input with a resistor to ground to put the impedance of the preamp at something sane (20k-40k?) rather than the native impedance of the opamp?
What you put at the input depends on the source it's connected to.
It's good practice to AC couple the input to the opamp and use a high (say 470k) resistor to define the DC conditions (ground reference). The AC coupling allows for "anything" that might end up getting connected to it that happens to have a significant offset. Something like a 5532 would give the best noise figure for this application, and allow a sensible value of coupling cap of around 0.47 to 1uf with 470k . The FET opamp is better noise wise at lower values of R, say 10k, but that means a much larger coupling cap in the 10 to 22uf range. The FET device would give a lower DC offset too perhaps not requiring a cap at it's output.
tbh, noise is the least of your worries with all this from a practical point of view... what you want is the correct matching and levels ultimately, so the OPA2134 is fine.
Greatness! I hacked together a buffer as above, replacing the 0,1uF caps the LM1972 wants with a pair of 0,47uF polyester caps followed by 470k resistors to ground. At the output of the opamp, I've a 2x1k voltage divider that's the input to the attenuator. Now the highs are crisp and clean again!
I tried setting the output opamp to a gain of 12dB but the output became too noisy. It's now at 7dB and it's back to its former levels. It's still a bit noisy (I can hear it but only with the ear about a foot away from the speaker) but I can live with that. It's about what I got from the chipamp before I put in the preamp.
There might still be slight problems with the pre, but I'll leave it for now until I get a hold of a scope and and design an updated PCB to accomodate the input buffer. I also have some slight DC issues, so I'll put back the 0,1uF caps before the LM1972.
Thanks all for your input! 🙂
I guess the OP is done and happy.
But fiddling around with my own preamp I discovered this:http://www.rane.com/pdf/ranenotes/Unity_Gain_&_Impedance_Matching.pdf
And I wonder if it comes into play here...or for that matter at all in my preamp?
What became of this preamp issue?
