The Broskie Cathode Follower for a DAC
John Broskie over at www.tubecad.com has a lot of interesting ideas.
One of them involves using a special version of the cathode follower as a balanced to single ended unity gain stage for a dac (like eg. the Wolfson Vout dacs).
I am trying to figure out the correct values for the Rk and B+ in circuit below when using the Russian 6N6P tubes.
Typical values for this tube are:
Ua = 120V
Ia = 30 mA
Ug = -2V
Is the Rk calculation as simple as:
2V/30ma = 66.67 ohm, and are they identical in value?
And the B+:
120V+2V *2 = 244V ?
I suppose that it is not this simple! :xeye:
And will I have to lift the heaters of the upper tube (as you normally would in a high voltage SRPP stage)?
Hello !
As I can remember a discussion with a dyer, about these tubes on Aikido, his advice was 200-240v, with Rp=Rk, about 390 to 420 Ohms (never tried by myself)
I built something similar, but with a low B+, and 6gm8 tubes : B+= 24v and Rp=Rk=180 Ohms. The advantage is that you manage heater and B+ with 2 lm317 (2 slow turn-on PSU on a 5x4" board)
My Dac is a cheap board, with CS8416/cs4397 , with Dale resistors and blue Elna Caps, (added some Oscon and solid tantalum), bought on Ebay ~80$...Now sounds terriffic !!!(not yet boxed, too much pleasure to listen to )
Hope this help !
R.C.
Hello !
The Broskie Cathode follower, schematic as above, is a buffer, used in an output balanced voltage DAC (ie : cs4397,cs4398, opus 874x, etc...) .
The gain is near 1, the output Z depends on tube you would use
The main advantage is to cancel DAC noise, and give an unbalanced output from balanced DAC...
Don't mismatch with an Aikido !!!
R.C.
