the british invasion(ATC,Volt,SS)
Well I have been at this a while and here is my prototype """2"""....Dual 12" Volt 3143,dual ATC 75/150(non S)(although I am looking for some S if anyone has some),dual SS 9700(one is a rear fire with fostex attenuator) and a center channel with dual 8" volt,1 ATC 75/150(S),SS9700.I have no paint or veneer and probably wont untill my third set(and last i hope).I used 1"MDF with1/2"baltic birch and 2" BB front baffle on the bottom cabinet,3/4" BB on top and 1"BB on CC.I have crossovers designed by Solen,but will look into improvements for my top cabinets.
the attachments must be to one of the formats acceptable to the Forum.
The pixel count must be no bigger than the Forum limit for that format.
The bits must be below the Forum limit for that format.
Compress using software that exports in the format that you want.
If necessary reduce the pixel count until the file size is acceptable.
800 by 600 is usually detailed enough to see all that we need.
You could go to 1000 by 700 for a bit extra but little information is added.
Do not post wide 1200+ pixel pics. They run off screen on most monitors.
Hi Andrew,although Canadian,my familly is all Mcleod's.Colquhoun's and Murry's
One day I will make it to Scotland.
These pics are off of Audio Circle as I am computer shy on Compression???If I had a email address I could send the big copies.Here is my pic eith both tops in place
