Hi Tim
PACE Inc. has been making solder stations and circuit repair kits for longer then I've been in electronics.
Pace Direct - Product Home
The thing is - it is expensive gear and the parts are expensive too.
But then I was trained to solder to NASA spec's and repairing PWB's to those standards is hard to do.
These guys sell some of the circuit repair kits - but with out the training and right gear getting good results is a real shot in the dark
Basic Cir-Kit - Stanley Supply & Services
For low power circuits using the small wire that comes with wire wrap kits works well - we used it all the time for repairs and circuit changes.
30 AWG Pre-Cut & Pre-Stripped Wire Wrapping Wire (50pc./pkg)
Can you post a photo of the damaged trace?
Is there a reason that you don't want to use wire or desoldering braid?
im repairing a memphis 1000d power supply driver card and the spot where the two drivers are have burned that whole spot the traces and the board.
