Whatever the datasheets suggest about Vceo, the SOA graph from the datasheet means they are only good
up to about 40V power rails with audio and that limits power.
They are old, slow and not too linear which rules them out for Hi-fi, IMO. If you must use them, a circuit designed
for complementary Emitter Follower output with 2N3055/MJ2955 or similar could be adapted. It seems there are
already several designs using these transistors that are published on Chinese websites such as this one
Google Image Result for http://www.seekic.com/uploadfile/ic-circuit/20116243338991.gif
The shiny old metal cans seem to have cult following!
It seems there are
Have you noticed the resistors "values"...??.
Yes, all seem to be 10K. It must be a simulation "problem"....like having absolutely no clue
or posting the wrong image!
But others are worse - no wonder some guys from that region keep wanting schematics
that are "best". Of course there are no best circuits for those darlingtons in audio unless you
only want a guitar amp and maybe can scale down this Marshall.
http://www.drtube.com/schematics/marshall/3315-5150-pa.gif
or maybe follow up the leads on this old thread: http://www.diyaudio.com/forums/solid-state/16280-amplifier-uses-mj11032-mj11033-3.html
As you can probably tell, there is not enough interest in those parts to offer a
range of designs that could be called "best". They just ain't "best" audio parts.
