The Aleph-X
Harry might be wrong here!
Harry,
I agree that a matched j-fet pair may better offset characteristics but mosfets will sound better.
Jam
P.S. That's for everyone that thinks that I agree with everything you say. O' Great One .😀
As it happens, I launched into the R&D on this thing without a decently matched set of IRF9610s on hand. (Poor at the moment...kinda stung to place orders for the parts for this thing.) Some of the imbalance I was fighting in the beginning was due purely to a notably imperfect front end. I remember grousing to Nelson in an e-mail that I needed a decent differential, and mentioned that the '389 might make a good choice. Another point in its favor is the inherently tight coupling, thermally, harking back to the point we were talking about earlier about having the differentials on the same heatsink.
Incidentally, for those who might be wondering, Q5 & Q7 (the input differential) don't really have to be on a heatsink at all. The power dissipation is really quite modest for a TO-220 device and they're quite happy to be naked. If someone chooses to run this circuit at a higher voltage, then the power dissipation will eventually become an issue. The only reason to heatsink them at this point is to keep the two devices tracking the same as ambient temperatures change. And change they will...this thing puts out a fair amount of heat.
I don't have any 2SK389s on hand, and have pretty much hit the limit monetarily. Amongst other things, I'm planning on Caddock resistors for the MOSFET sources and outputs and what with the new IRFP044s etc., alternate front ends will have to wait...probably for quite some time. Sad, but there it is. Another problem is that people seem to feel that there are a great many counterfeit Japanese devices being sold out there; for every person who says that they are happy with the devices they bought from business A, another comes along and says that A sold them bogus parts, but they are happy with parts obtained from B, then another person comes along and says that B sold them bad parts, and that he likes vendor C...and so on. It would be nice if the 2SK389 was available from someone like Digikey or Mouser (where do they come up with these names?) who you could count on.
Maybe someday.
I still don't know what I'm going to do for bulk power supply caps. I thought I had a box with a bunch of 25 & 35V caps in it. Turned out they were 7.5 and 10V. Ooops! For the time being, I'll toss in some mongrel 60V caps until I get a chance to knock over a little old lady and steal her lunch money.
And to think it used to be the young, pretty girls who ran when they saw me coming...my, how the times have changed.
Grey
Jfets are not drop in replacements for the mosfets. You may be comparing apples and oranges if you are using them in the same circuit. They are great diff pairs and I have heard them sound great in several products as well as my own designs. I heard a rumour that Nelson Pass even uses them in some products....... You know a couple of matched J109s in parallel with an Idss of greater than 8mA would just about drop into Grey's.......... neverminds, everyone forget what I just said.
"It would be nice if the 2SK389 was available from someone like Digikey or Mouser (where do they come up with these names?) who you could count on." They are MCM and Consolodated Electronics.
By the way I have never seen any counterfit japanese transistors, sounds like a case of audiophile nervosa to me. But that could never happen, right?
H.H.
GRollins said:
I know at one point not too long ago, Joe Berry sent me a schematic of an Aleph-Xish kind of circuit. It wasn’t like this one, but by the second or third try he had the differential cross-over trick in hand, but nothing in place to handle the DC offset. I believe he was modeling the circuit, rather than building it. What he ever did about the DC, I don’t know, as he was one of the people I quit responding to ‘cause I just couldn’t afford the time.
Hi Gray -- just to update you:
That first schematic was to show that two independent single-ended Aleph channels could be bridged to give su-sy behavior with no DC offset issues. It worked well in the simulator, but on closer examination, I found that it needed to have a balanced input signal, so I became a bit disenchanted with the approach.
In exploring a second possibility through email exchanges with NP, I also ended up with essentially the same schematic as the one you've posted here. My initial reaction to 30 ohms from each output to ground was also similar to yours, but it helped me to imagine them as finned aluminum units bolted to the inside rear panel at the speaker binding posts, rather than taking up lots of PC board real estate. Nelson himself suggested that the resistors could even be incandescent lamps a la Zen Lite. ;-)
I did model several variations of the circuit, and used thermal DC sweeps to play with the effect of different values of output resistance. I ended up adding a couple of regular diodes in series with D1 -- one to counteract the thermal trend of Q3/Q8, and a second to cancel out D1's thermal drift. This improved absolute offset stability in the model, but Nelson seemed to see this as an unnecessary complication, so it may not matter much in real life.
I also proposed a relatively simple DC servo design as an alternative to the power resistors at the output. This seemed to work quite well in the model. But again, NP seemed to think that this was an needlessly complex solution.
I look forward to hearing more about your progress with an actual prototype. I'm quite sure the results will repay the effort!
Grey,
I have been waiting for this since the CES ended, cool!
What about a mini-aleph-X set up to give you the same power as the mini-me, sorry miniA with +/- 7.5 V? You would get to use all your 10V electrolytics.
HH
never seen fake Japs? Try buying 2sc2922 from MCM and see what you get!
Another thing that spoils the fun when buying japs is the morons that work in the stacks at places like MCM and such. You see, all the japs transistors come in very carefully selected gain ranges with super low gain distribution in the groups, so you may get the real deal but what good does it do if they give you different gain series?
I would gladly pay 10 extra cents to get semis from the same gain groups but no vendor seems to have the time and power to accomodate my humble request.
Very nice work, Grey. Thank you. I just went through this thread.
Some observations:
Looking inside the X600 I cannot spot any 2sk389s ( There are two of them in the X0.2 at least). Only IRF610, IRF9610, IRFP240, IRFP9240 etc. There are separate bias and offset pots (5k) for each "side" of the amp and another one for the input (?). Except of the output section and a - thermally coupled - pair at the input (?) all other MOSFETs are sitting on their individual heatsinks.
And I do not see any Caddocks etc.
You may wonder from where I poor boy know all this: I am - sigh! - not looking at my own amps, just marvelling over the glossy images printed in the German mag Audiophile 3/2002...
Klaus
Joe,
Good to hear that you managed to beat the thing into shape. I make no claims that this is the be-all, end-all...that's why I called it Version 1.0.
Incidentally, my intention--for mine, at least, you guys can do as you like--is to build something along the lines of the old Mark Levinson ML-2. 25W into 8 ohms, 50W/4, 100/2...given that the Magneplanar ribbon tweeters are around 2.5 ohms, the Aleph 2 is a less than perfect match. The bias isn't high enough. The solution is lower rails and mucho bias current. As I said above, +-12V rails will give the right general output voltage, and I'll be putting in .15 ohm source resistors, which will bias the outputs to roughly 3 amps per side. Also reduce R16 to 1.0k. Yes, I intend to regulate the rails, although I don't know if I'll make it quite so fancy as the ML-2's regulators.
Harry,
Note grataku's post about parts. Like I said...I'd love for Digikey or Mouser to carry the Toshiba JFET pieces. I'm too tired/lazy (four hours sleep last night) to look, but I believe that Digikey already carries some Toshiba parts (perhaps Mouser does also, don't remember). Surely, it wouldn't be too much trouble for them to stock JFETs as well.
grataku,
I guess the ultimate goal here would be to go for a 1W amp (I've also got--I think--some 5 and 6V caps if some one wants to trade). Sadly, none of the speakers I've got on hand are efficient enough to take advantage of such a thing. Horn speaker fans, take note.
micke,
45V? Whoa! Monster amp! Keep in mind that the rails on Nelson's 200W version will be on the order of 32V or so. According to some rough calculations I just did, 45V rails would put you in the vicinity of 400W into an 8 ohm load, but you'd be running 1300W of pure heat (looks like about 14A total bias). Now, that would be a serious project, indeed.
You might want to go water-cooled on that...
Klaus,
The Caddocks are just something I wanted to do as a DIY thing. Nelson's got to strike a balance between sound quality and parts cost; he's got to show a profit. Still, might be fun to take one of Nelson's production pieces and retrofit it with Caddock stuff to tune it up.
Grey
Grey,
I am not kiddin about building small stuff like the mini-AX I mean come on! How much power is enough power? More to the point how much weigh in aluminum can your floor support? I just got done _sort of_ building 4 hiraga monsters, and 2 Hiraga le crappe'...er le classe A for my active MTM system. Anyways to make the story short, which is related to the crappy vendors we discussed above, and maybe come to think of it, to the 'real' reason why Nelson is building single ended amps instead of push-pull (damn genius if you ask me), I want to go to single ended specifically, to mini-A....where the hell am I going with this?(sorry I had 0 sleep last night up all night working and not at stereo-building) oh yeah... I think that with 36 W total x channel I have pleeeenty of power. Maybe I am getting old but my ears seem not to be able to put up with high volumes anymore. No that's not listening fatigue or the fact that deep down I am not satisfied about my system...well...I am not but for other reasons.
Is anyone there that just turned thirty-something having the same hearing affliction?
'odd damn I m so *******' tired
R21 revisited
Grey, I think I misunderstood the role of this resistor earlier, based on a flawed memory of the Aleph 30/60 grounding scheme. After re-checking the A30/60 schematics, I now believe that R21 is there only to float any RFI that may try to couple between the amp's ground and the input via the parasitic capacitance of D2-D5. If this is true, then your initial connection is correct, of course. My oops, sorry!
Joe,
Just to mess with your head, notice that Nelson uses it (on 30 & 60) under the + input resistors, but not the - input, which goes directly to ground. At any rate, 3 ohms is far, far less than the part to part variation you'd get from using even a 1% resistor.
To anyone who wants to really shave this circuit down, you can remove R21 entirely. Also D2-5. You'll be exposing yourself to the possibility of ground loops (not really a common problem) and opening the door to static discharge blowing a hole in your front end MOSFETs. But if you're careful when hooking and unhooking the signal connections, you don't really need them. Note that the A-75 doesn't have them, and there are a number of those cruising along happily even as we speak.
The caps I omitted from the back end, the ones across Q3 & Q8 that Harry was mentioning and the one that the Alephs have (but the Volksamps don't) between the feedback line from the output and the output MOSFET's Gate are my way of streamlining things. If it makes you more comfortable to have them in there, by all means put them in, but I've found the circuit to be quite well behaved so far. Who knows, I may go back and put them in later--I just haven't seen a need to do so. The circuit just doesn't seem to be twitchy in that manner.
Now, DC...that's another matter, entirely...
grataku,
Volume itself doesn't offend me--it's the content that I find bothersome sometimes.
Just as I intend to run my copy of the amp at 12 volts, there's no reason you couldn't drop the rail a little further. But once you get below about 10V, you need to reevaluate some parts of the circuit. The current source for the front end will have to be redone, for instance, since once you get below 9V, D1 won't turn on. This isn't a fatal problem. You could use a 6V Zener, for instance, and drop the value of R24 accordingly. Or you could just abandon the Zener strategy entirely and use another MPSA18, playing its Vbe against R24 to set the current. Looks like about 33 ohms for R24 would do the trick. Using a transistor to watch the voltage drop across R24 would not only give you a lower voltage drop across the current source, but would also be a better performing current source because the feedback loop would tend to reduce current variations that the Zener strategy doesn't even notice.
Thirty-something? Hmmm, I'm 44 and confess that I got really bored with what passes for rock these days about five or ten years ago. After a period of aimless dissatisfaction, I shifted sideways into jazz rather abruptly and have been quite content with that. It's improved my entire outlook on life. Classical remains constant in interest level.
To those who might feel the need to defend their favorite group a quick story (which I may have related before, don't remember): Just for fun, pulled out In-A-Gadda-Da-Vida by Iron Butterfly to play for one of the sprouts a few months ago. Now, the title track is pretty much unique, but when I turned the record over and started playing the songs on the other side, she started giving me this,"Why, that sounds like XXX, and the other cut sounds like YYY, and...oh, listen...that sounds like ZZZ," nonsense. My reply was simply to show her the copyright (1967 or '68, something like that) and ask her who sounded like whom...after a few moments of embarrassed silence, she conceeded that perhaps I do have a point when I say that all the stuff that you hear now has been done before--and frequently done better the first time around. The phrase 'been there, done that' was invented to cover situations like this. Just as the early rock players listened to blues and jazz (and in some cases classical [Yes, for example]), the current crop are listening to early rock. Unfortunately, the relationship becomes a little too incestuous at that point and creativity suffers.
Come to think of it--and now you've got me waxing philosophical--perhaps that's why I'm not all that interested in the standard three-stage solid state amp. Self, Slone, and others have pretty much flogged that topology to death. I'd rather mess with something newer and less picked-over.
I'll think about this some more. It's an interesting point.
Grey
Re: R21 Revisited
GRollins said:
. . . notice that Nelson uses it (on 30 & 60) under the + input resistors, but not the - input, which goes directly to ground. At any rate, 3 ohms is far, far less than the part to part variation you'd get from using even a 1% resistor.
Yep, exactly that observation led me to rethink its role in the circuit.
Maybe we should ask NP's advice on this one. He's normally pretty ruthless in weeding out extraneous parts. On that basis, I looked for a reason for having an "R21" in the A30/60, and (think I) found it in D2-D5 and the AC noise suppression caps which shunt power-line RFI to the chassis. If these caps OR D2-D5 are present, R21 also may be advisable; I'm not sure I'd trust the circuit's inherent common-mode rejection at these frequencies. But I will of course defer to the Designer's opinion.
I intend to run my copy of the amp at 12 volts . . .
Are you implying the use of a rechargeable battery supply? Now THIS I think could be the really trick setup, giving a decent 25W or so output swing (assuming +/- 12V), and of course, making both supply regulation AND RFI management less of an issue.
batteries for HarryHaller
HairyHowler,
Once you regain your composure --
What would you say to a hybrid approach? The amp could have a conventional internal power supply, which could also serve as a charger for optional external batteries. A switch on the back could determine the operating mode -- AC, Battery, or Recharge.
Or do you reject the idea of battery power altogether as not offering a worthwhile improvement, based on your own experience with same?
Batteries
I don't know, it never occured to me put batteries on an amp that draws several amps. I would rather put to money in a a good regulated supply which can sound excellent with attention to details in design and construction ie. soft recovery diodes and good caps.
H.H.
regulated supply
HH, I really don't know if battery power is worth the trouble either. I only want to point out that it's a feasible option in the context of this project. This is even more true if you are already planning to do a regulated supply, because the raw DC requirements for a regulator and a charging circuit are about the same (+/-17 or 18V in this case).
A quick google search on "lead acid charging circuit" turned up several schematics, all of which are about as complex as a regulator. The major cost for battery operation is going to be the batteries themselves, but I think you could add a battery option to this project for about (US) $200 that would give you 3-4 hours of operation per charge. At that price, I for one would be tempted to experiment with it. If nothing else, it would be a (relatively) cheap education.
Joe,
While I did mention battery operation as an option for the Mini-A, it would be pretty rough with this amp, considering the bias requirements. The +-12V rails popped out of my calculations simply because I plugged in 25W/8 ohms as my starting point for output. Given that the ribbons have such a low resistance (purely resistive, thank goodness), I've got to bias heavily, and a lower rail brings down the device dissipation to a 'reasonable' 35W or so. Actually, given that the power into 2.5 ohms will be far more than I anticipate needing (I only run the tweeters from 5kHz on up), I could drop even further, but I'm kinda hung on this silly ML-2 image I've got in my mind. No, I've never owned a pair--just kinda like the conspicuous overkill approach that they represented. I suppose I could just as easily get by with 10W/8 ohms and let that double, but then grataku would show up at my door, wanting to borrow the thing all the time.
One option related to battery power would be to use higher impedance speakers; at least 8 ohms and maybe 16...does anyone even make 32 ohm speakers anymore? Anyway, you could reduce the bias considerably if you happened to own high Z speakers. Maybe you could series several drivers. If you happen to have even 8 ohm speakers that have a relatively flat impedance curve (say, minimum at 6 ohms or so), you could back off on the bias quite easily, thus making the battery option more attractive.
I've always regarded battery power as being more appropriate for preamps and such, although I've seen that there are battery powered amps out there. No, I've never tried it...have no opinion as to whether it's better or worse.
Oh, R21 is to break ground loops.
Harry,
I had intended to abuse the amp some more, trying to force it into instability, but have run out of time today. Perhaps tomorrow...maybe...I've already got a lengthy list of things to do before I go to work. If I can make it misbehave, I'll stick in some caps. No electrostats on hand; I'll have to make some kind of nasty load. The Mini-A was pretty much bullet proof, at least here, so I don't anticipate this being easy. About the only thing I can see is RF, which is kinda a non-issue in central SC. Most of these people live in the Stone Age, and distrust newfangled things like light bulbs. They won't get to radio until somewhere around the year 2135. Perhaps someone in NYC or LA could build one and comment on RF stability.
Grey
