The Aleph-X
Some problems with the X
After a burned channel I have managed to replace the output fets and now the smoking sourceresistors are gone 🙂.
Setting the bias to 2,3 ampere a side everything looks oke (measuring 0.5 volt across R5 and R40). But the absolute off-set is very high, 7 volt and 6,5 volt 🙁. The off-set on the speakerterminal is ~ 1,2 - 1,5 volts.
Have the Aleph-X pro's suggestions what to check?
p.s. before the channel smoked the off-set on the speakerterminals was very low, ~10mV. So I thought the diff-pair would be oke.
Re: Some problems with the X
Check your diff-pair. It could have gone to heaven after the smoke. :clown:
Unload the big caps before measuring or soldering.
I had several diff-pairs blown from a +/-5V remaining voltage over the caps.
/Hugo 🙂
Re: Re: Some problems with the X
/Hugo 🙂
I measured the diff-pair on the board, when replacing the 4 new outputfets, there was no short and the 2 halves behaved the same. But I will dissamble the 2 fets and will measure things out of the boards.
Still problems with 1 channel of my X. Edwin suggested to measure r23 and r25 the results are:
r23 4.88 Volt
r25 4.82 Volt
All the three irf9610 fets are matched at 2 mV so I switched the irf9610 of the broken half with the one of Q6 and put at the place of Q6 a new (unmatched) fet. I still measure a off-set of 1,3 volt at the speaker terminals.
If I find some time I will dissamble the channel again (out of the case) and check the resistors. Does anyone have an idea of what to check?
I am also planning to order a new diff-pair ...
An offset of 1.3V is not that much.
All components will probably be OK.
Does the amp play well?
The most important is a well-matched diff-pair and at least 1% resistors for R23/25. Whatever is easier for you is ok; matching diff-pair or swapping resistors.
I mounted the diff-pair like this: http://www.diyaudio.com/forums/showthread.php?postid=173696#post173696 so I could easily substitute the fets till the offset was almost 0.
Trimming V1/V2/V3 can improve a little.
V3 trims the differential DC but also affect the absolute DC a bit.
Adding resistors between the outputs and the common sources of the diff-pair helps stabilizing DC. Something like 2k to 5k should work. 2K is a bit low, but it worked best for me.
Hope this helps.
/Hugo 🙂
Thanks Jarek and Netlist I have now swapped some more irf9610's ( I had bought 6 matched irf9610's) And I have now an off-set of 140 mV. Still a bit high, so I plan to order some matched irf9610 (localstore).
I checked every resistor and zener diodes and they were all okay.
Oh Yes!!
It's playing, what a nice sound. But the differences with my 1996 JLH 15watt are small. The bass of the XA is better and the highs have more definition but that's it.
But 1 channel has with a pre connected 200 mV offset the other 30mV. But the amp is deadsilent. I will get a new diff-pair and fix that problem.
The amp get's very :hot: ca 60 -65 C. Ambient is 25+
Is that it? Just better lows and better highs? That's too bad. 😉
When I play mine playboy playmates all of a sudden appear in the room and start giving me free lap dances.😎
Seriously, a different pair of speakers are more likely to give that 'WOW' different sound that you expected.
Yes the soundstage is absolutly better, but the JLH isn't very bad neither. Everything is better and clearly hearable, but it's not fair to say the JLH is a bad amp.
Improvements in one's system due to electronics are usually adiabatic, experience a few of these improvements and you'll have a great system without even knowing.
Any system sounds great until you hear a better one, if you ever go to an audio show you know exactly what I mean. No one said the JLH was bad, the question is will you switch back to it?
I walked into a tweeter center...I know, I know...I was just walking off my lunch, anyway this guy was drooling over a pair of sonus faber that sounded like absolute crap, no bass no body thin highs, just crap. I am sure that someone listening to a better system than mine could make just exactly the same observations about it.
Taco,
I agree, the JLH is an excellent amp and was my entry in Class A. I recall that design convinced me Class A was a must have.
The X Aleph for JLH owners is in effect a monster version of the JHL with more refinements such as dynamic contrast & bass definition as noted elsewhere.
macka😉
