Thanks Russ to help me fix the Trident 1.2V issue.
Cheers
Felipe
Your welcome. 🙂
Out of curiosity - and because the threat now is gone - what was the failure ?
I deleted the thread only because nearly all of it was a wild goose chase. The problem was a cold solder joint around R4 on the Trident, which is the user installed resistor.
Yes, we were around. Good to have Merlin is back in audio.
Thank you.🙂
I suspect that Tridents needs the new Placid better than my Salas V1.2R, when will be available & how much will cost?
My 1st Placid is running the first BII with Tridents, the second one is running the second BII with Tridents, Mux and Toslink module. Neither one is at the end of it's range. Both are stock Placids, latest version (as far as I know).
Not at all.
What current & voltage are you using in your Placid?
- More Vendors...
- Twisted Pear
- Thanks
