TFT-Screen cleaning
I got some dirt on the backside of my tft screen (the actual display), and it is kinda
sticky and won't come off by just wiping it gently. Anyone got experiences on how to clean the backside of a tft screen and
how much pressure it can stand (is there a protective plastic layer ?) ?
I don't know, if I could use cleaning alcohol or something like that.
Thanks for your suggestions 🙂
cu,
Cyberdemon
petroleum benzine
The following cleaners are acceptable for LCD panels:
Water
IPA (Isopropyl Alcohol)
Hexane
Petroleum Benzine (The best)
NOTICE: The following cleaners are unacceptable:
Acetone
Ethyl alcohol (save for drinking instead😉)
Toluene
Ethyl acid
Ammonia (WINDEX)
Methyl chloride (DUH, paint stripper)
You can get Radio Shack Electronic Cleaner in a can, it's a benzine/hexane type solvent that works great.
Apply the cleaner to the cloth, and then stroke the cloth across the display in one direction, moving from the top of the display to the bottom.
