Texas RC4558
I do not recommend 4558. Although waste is a bad behavior.
And the operational amplifier does not have much difference in practical application
But I still recommend using 4580 instead of 4558.
Maybe we will waste a little money. But it will save a lot of time.
I started this thread because i have bunch of unused RC4558 purchased from RS COMP many yrs ago & i wanted to know if i can take advantage of them in non critical audio use.
For my diy builds i always use opamp like TL0XX series, NE5532, LF353 etc. But i would love to try exotic opamp like AD & OPA series in near future.
You can use it in any audio circuit.
The same environment as ne5532.
In fact, I won't hear any obvious difference. I do not recommend using expensive operational amplifiers.
It doesn't make any sense.
4558 is fine for low gain medium drive (2000 ohm) circuits. Graphic equalizers are full of them. Two years ago I built a pipe organ shade driver (volume doors) motor drive with 10 of them.
At 50x gain, they were the source of the hiss in my RA-88a disco mixer. Wrong part for that much gain, the RIAA input. 33078 sounded much better but required power rail decoupling (scandalous) and 33 pf around feedback resistor to stop oscillation.
I've never needed an OPA or Burr Brown anything for my needs. 4580 is a workhorse and about as cheap as 4558 if buying new. 5532 is cheap and quiet but a power hog.
