I realize most harmonic distortion testing is done on a infinite baffle but was wondering if the tests would be valid between drivers if done in the same enclosure.
F3 and QTC will vary with the different drivers. The Qtc varies from about .0703-1.07 in the test enclosure.
I have a 0.3 cu ft enclosure I can mount them in for testing and will build the proper enclosure once a driver is chosen.
I have a couple pairs of 6.5" and am looking at using a pair for midbass/bass duty for my moderate home theatre. Frequency response will be F3-120Hz.
