I recently acquired a transformer for which I can't locate a data sheet. I would like to test it but at his point I am unsure of the primaries. The transformer has no serial number but here is a picture of the specs:
I measure the resistance in the primaries and find that if I assume that brown is the common, orange has 2 ohm and red has 4. I would assume that more copper has more resistance which would make the red the 230V lead and the orange the 115V lead. Am I far off here?
I suppose if I have that much right, it's safe to move forward with the bulb test. I've searched the forums a bit but I haven't found anything suggesting what wattage should be used to do that. Any advice?
[IMGDEAD]http://www.bramofon.com/piccez/power2.jpg[/IMGDEAD]
