testing a bank of mosfets
After any modification always switch on via a light bulb tester to reduce the damage if there is something wrong.
If all is OK the voltage will come up to around 70% to 90% of direct on line voltage and will allow measurements to be taken.
Once you know that the amp is correctly wired and that the output bias is set to minimum, then remove the tester and switch on again.
Set the bias voltage and measure the individual currents of each of the output devices and of the drivers.
If they are within 10% of each other you are probably OK. But much more likely they will have a current spread approaching 2:1 (highest bias : lowest).
