These scope based tests remind me that Soundcard Scope is free and does all the usual LP tests very nicely.
Soundcard Scope
Of course there are many applications that do the same jobs, but they don't pass from cartridge-tonearm-turntable-prephono chain, this is why are used test LPs, I suppose.
It's interesting that B-K chose not to apply the high boost of the RIAA curve. (thanks PABA for the link) That's one way of cutting higher level sweeps.
THe STR series has those too.
The issue is if we aim for 3 decades frequency range (20 Hz - 20 kHz) at constant velocity, the top end would diminish in noise, due to amplitude limitation at the low end.
For that reason they should start at 500Hz like the CBS disks do.
That is useless for setting antiskating.
Right, I was going to say the same thing.
Useful or not?
Useful or not?
They go up to 50k that would be useful. Removing the hi frequency boost probably removes most of the problems with cutting this track.
Here's the link
Test LP - Google Drive
Thanks for this, Pano.
But when I clicked on the link ... it took me to a page which showed:
Folders:
* Artwork
* Graphs
* Software
* Test Signals
* Useful Info.
Files:
* Back Cover
* Internal Documentation
* Pressing and Mastering
* Progress Tracking
* Track List v3.
But no spreadsheet for names??
Andy
New to this. No time or intention to read the entire thread.
Years ago I toyed with the idea of making my own test LP, being totally dissatisfied with all modern releases (centering, accuracy of signals, usefulness of signals). I gave when I understood how hard it would be to, remotely, control the final quality, Oh well.
Just a few considerations:
1) How do you ensure that the intended test signals can be cut and pressed at all? How do you ensure that the mastering house does not interfere, knowingly or unknowingly?
2) How about cutter VTA? This must be in line with the VTA of commercial releases, and known. Is there a VTA setup test signal?
3) Did you consider a test for dynamic drag? A regular 3150 W&F tone, with on top of it pink noise keyed on and off at a level and rhythm commensurate with music.
Good luck.
Good luck.
Hi Werner,
-Chris
The extra noise will confuse the PLL in the W&F meter. It might work with different levels of 3150 Hz, that I don't know. I have seen service shops put a box on a turntable they were testing to generate drag from windage. You could measure the speed with no box compared to the speed with the box mounted. All we need to do now if define a standard box for weight and area. Then we can calibrate them and sell tha twill the record.Did you consider a test for dynamic drag? A regular 3150 W&F tone, with on top of it pink noise keyed on and off at a level and rhythm commensurate with music.
-Chris
- Analogue Source
- Test LP group buy
