tesla speaker spec's
frugal-phile™
Joined 2001
I’m guessing the vintage European drivers.
ARO 666 attached.
dave
found another pair today in a Fleetwood console now to figure out what to do with them?
this pair was accompanied with some japanese tweeters and that same bizzare wiring scheme...yeah it was a Homer moment earlier when i was tracing things out...duh!
the 388 could be interesting by themselves if these specs are correct
Properties Input power RMS: 1,5 W
Input power MAX: 3 W
Impedance: 8 Ohm
Freq. range (Hz): 150-15000 Hz
Sensitivity (dB): 86 dB
Diameter: 100 mm
Mounting depth: 30 mm
Mounting hole: 100 mm
Basket material: Fe
Membrane material: papier
Weight:
0.18 kg
