Tempest help
Hey guys, I recently finished my tempest sub. Its in a 122 litre sealed box getting 300 watts of power. I really do enjoy the sound of the subwoofer, great output, great depth, probably one of, if not the best sounding subs ive ever heard. However sometimes I find it could use a little more.. slam.. a little more punch on drum beats and what not. what im wondering is, to get this, should I go with the 65 litre sealed box, or switch to a vented enclosure. I really dont want to lose and of the Tightness of the sub, I just want to gain a little more punch, if that makes any sense.
the perception of lack of "slam" is the comparative flatness and lack of a bass hump that you're used to hearing in boomier and less flat subs.
My advice is to leave the sub as is and attempt some kind of EQ, either on the sub amp (if so equipped), or via some kind of pre-EQ, if not.
Fact is, the sealed sub is giving you lower group delay and better transisent performance, flatter response... all good things. Don't throw that away because you're looking for some punch.
Use your receiver's loudness control if you're desperate 😀
Best solution, buy a BFD (feedback destroyer), and EQ your room while you're at it.
GB
One thing I wonder about, Is would going with the 65 litre High Q box still sound good for mostly rock music. Keep in mind I use my system for about 95% music. Sub 20hz extension isnt to important (although i wont complain if i have it) also, I do find the 122 litre box to be rather large, so thats another pro I can see to using the 65 litre box. Im just woried about lossing overall volume or SQ, or being to boomy
