telex Video In option question?????????
Ok well I have a telex m2x and it does have the video option installed( the actual video card is in the panel) So when I plug the composit in it goes to a snow screen but never shows the video. So what I wanted to know is if any of you know why this is happening and if Im just overlooking something, or mabe the video option is just broke? thanks for any Input
What are you using for a signal source,ie DVD,VCR,etc?Do you have another way of testing the composite cable as well as the video source to ensure they are sending the signal? Also has the panel worked when used with a computer as the signal source?
have you had both computer and composite plugged in at thr same time and tried the vid switch on the face of the panel to see if it can switch properly from one source to the other. also do you have the remote for this panel.it also has a vid source switch on it.
