Tektronix 2225 issues
I have got an used Tek2225 where the basic functions seems to work. A bit of noise in the pots but when worked a bit they got a bit better but not perfect.
I have found one issue which I would like to ask if this could be a calibration issue.
When CH1 is set to GND and I use the vertical position to align the beam at the center (zero-line) and then pull the X10 vertical magnification then the beam jumps "out of the screen". I am then able to get the beam back by using the vertical position.
Doing the same with CH2 the beam does the same but here I am not able to get the beam visible again.
Could these issues be calibration problems only?
Yes, everything looks nice when not using the X10 vertical amplification and on CH1 the X10 signal also looks good when I adjust for the "DC offset". On CH2 I am not able to see the trace at X10. Not even when CH2 is set to GND. So far I have only used the calibration 1 kHz signal or have the input grounded.
