Technics SU-V7
Dear Friends,
I am trying to help fix an old Technics SU-V7 amp belonging to a cousin of mine. Everything is working fine, except the loudness circuit. On or Off makes no difference. Bass, Treble and filter switches are working fine. I notice that the Volume pot is a standard rotary 3 pin instead of a usual 4 pin pot used in loudness circuits. I checked the pot with a meter and it is fine. Can someone please some clues on what could be wrong.
Thank you in anticipation.
Rajoo
Check the switch operation with a meter and just trace the switch back...
This has to either physical, as in intermitent/faulty switch, or cracked print somewhere.
Without looking at a circuit I assume a 3 pin pot is correct and that it's not been swapped.
Both channels faulty ? Suspicious if so.
