Part of the amplifier is powered by a stabilized voltage. The terminal transistors and drivers are powered from another, unregulated, power supply.
Remove the left fuse and leave both out until we figure out the power supply DCVs. Measure 341 and 342 again.
I shut down the amp and turned it on again i heard the relay click. Now 342 measures - 39,4 DCV.
Both fuses are out now
The protection circuit and relays are powered from the main unregulated power supply. Operates from constant voltage at any output. The outputs are additionally protected by fuses.
The power supplies are bipolar with respect to earth.
The relay contacts disconnect the power to the output transistors. Check contacts.
OK, left channel is probably loading the power supply. Pull the right fuse and install into the left channel and measure 341 and 342 again. They will probably read 0VDC as the protection will be activated again.
Now we know the left channel is the problem channel. Do you know how to test transistors? We need to test TR409 and TR410 to start.
I'm out 'til Monday morning.
Craig
Craig
I'll Google how to measure the transistors. Thank you very much so far!
I'll let the dog out and of to bed afterwards.
Have a great weekend!
I measured the transistors in diode test setting on the multimeter. I didn't solder them out of the circuit board like some suggested. I guess the values are in mV ?
On the R pre amp
TR 409. TR 410
b-e 068. 069
b-c 521 1
e-b 068. 069
c-e 1. 566
On the L preamp
TR 409. TR 410
b-e 068. 004
b-c -1. 0
e-b 068 004
c-e 1. 004
On the R pre amp
TR 409. TR 410
b-e 068. 069
b-c 521 1
e-b 068. 069
c-e 1. 566
On the L preamp
TR 409. TR 410
b-e 068. 004
b-c -1. 0
e-b 068 004
c-e 1. 004
are the relay contacts ok ?
I hear the relay clicking when the left fuse is in. It doesn't when both fuses are out so i guess the relay is okg
The layout got a bit scrambled here.
TR 410 on the left side:
b-e. 004
b-c. 0
e-b. 004
c-e. 004
That's failed short circuit.
Sid
- Technics su-3500 fault search
