Technics SA-80 distorted right channel
I have an old Technics SA-80 receiver that pulled out to use with a turntable I just got.
I hooked it up and while there's no noise problem (doesn't buzz without a source), the left channel sounds great but the right channel seems to be distorted or otherwise buzzy. The audio is coming through just poorly.
I checked different inputs, different speakers in both main and remote (A and B) and same problem.
I should mention that a while back I took it apart and damaged the balance pot. With some help from the forum here it was determined that I could just de-solder and ignore. I can't remember at the time if it was buzzing, if it was I probably attributed it to lousy speakers.
I tried checking for bad caps etc, but a bad cap would cause problems in both channels right?
Anyway I got the thing apart and need some troubleshooting ideas.
