Technics FM Tuner switches from stereo to mono to beat of music!
Happy with it! Not ground breaking sound but good for the garage and my electronics tinkering space. Using it with a Pure Highway for DAB (BBC 6 Music) which has a built in FM transmitter for use in cars and works great for the garage. My car has DAB so no longer use it. The Wharfedale Diamond III's are not too bad and fit on a small shelf. Using it with my JVC AX220 (35wpc - diamonds hard to drive) but may try it with a Technics SU800 (50 wpc) which I have in the loft. All this kit (not DAB!) has lasted this long (30 years) so should survive a UK garage (dry).
Did this and fixed it - finally got round to it!
None of these, it's T101 for centre tuning. Use TP101 and TP102 for checking the center alignment. Tune to strong station, use a digital voltmeter. The polarity does not matter when measuring TP101 and TP102, all you care about is adjust T101 until you get as close as possible to zero volts between the 2 test points.
Check the AC ripple across C708 100uF/35V, it should only be about 10mV or less. It is possible that C713 100uF/35 that is part of the voltage doubler is dried up. C713 can be increased safely to 470uF/35. This capacitor has a hard life due to the amount of AC voltage across it. Increasing the capacitance will make it last longer.
Replace C705, C706 and C707 too.
Don't even think of installing boutique capacitors into this tuner, it is not worth it.
