Hello,
I'm trying to find answers to a question about technical issues that might effect the audio quality of the digital setup I'm trying to implement. I will be using an I2S Preamp/DAC unit that has jacks for USB and Toslink.
The standard setup most people will use is as follows: Laptop -to- USB -to- Pre/DAC.
However, I have a Desktop that's on the other side of the room from the stereo (about 18 ft). I'm thinking about implementing the system this way:
Desktop- to -WiFi Transmitter- to -Squeezebox (or Linksys Music Bridge)- to -Toslink- to -Pre/DAC
My Question is whether my setup creates any compromises in the audio quality (like added Jitter from the Squeezebox or anything along those lines) which I would avoid by going direct from USB?
One more question: my understanding is that by using the Toslink out on the Squeezebox it bypasses the Squeezebox DAC, making the Squeezebox simply a receiver of binary data, therefore, there is no reason to be concerned about the quality of the power source (regarding noise). Is this correct?
