A 3340 Capstan Wiring
According to the book, the wires on the Capstan should be Orange and Yellow. The Yellow should go to an Electrolytic Cap (C6) going to the Frequency switch (50-60 Hz). The only Brown wire I see is in the Tape Speed Switch (SW8).
Looking at the schematic, I would say this motor is not designed to run in reverse, as the primary seems to accomodate two different voltages for the speeds.
xmtrkidd
xmtrkidd
