Next week, I am ordering some Depletion SemiSouth SJDP120R085 JFET's.
I plan on getting a few for personal use and a few for others on the list who have shown interest.
If you would like a pair, let me know fairly soon. These will be $70.00 a pair. I won't have enough to match them.
Did you get that together? I have a gentleman in Russia
looking for some.
I got 10 of them for now, 2 of which I will keep myself.
I am going to match them the best I can, hopefully this weekend.
Have him PM me or direct mail if possible. Or I can PM you my email address.
hi tea-bag,😛
just to inform you.... iI replaced all 6 IRF240 with your SemiSR100, not only the upper part.
Sound changed again, a very dark soundscape,
first impression where are the highs?
second impression is there someone in the room (I was sleeping a little bit) voices very naturally .......
my last goal with this amplifier more power, I need new heatsinks, so I can drive a higher bias current.
I hope I have only this disadvantage:
" The most important topological difference is that the output stage current source is no longer an “Aleph” current source, but a version of the classic “Mu Follower”..... This approach was chosen because the JFETs can take better advantage of distortion cancellation than Mosfets, but won't do so if the current source is tightly regulated. This has a little less precision, but lower distortion." (Nelson in J2 pdf)
I drive the outputstage directly by modified Pumpkin.
have a nice day🙂
have a nice day🙂
did you change value of gate stoppers ?
Hi dear Zen Mod,
I took 150 Ohm! O.K.?
Papa sez 22R - in F1J thread
breadcrumbs ...... you know ..........![]()
o.k. I try to hear the difference when I am sleeping again....
f2j uses 47R, so it looks like lower is better.
Generg, I am confused, did you rewire it to be a mu-follower? Otherwise it's just a current source still, running on lower vgs critter, which probably isn't ideal.
I would worry less about sink temperature with these devices myself.
😀No teabag, i cannot do that up to now. But before sleeping I look at the BA-1 outputstage and parallel at the tries of people of the J2 thread and I try to see the difference.
I also bought "Audio power amplifier design handbook" from Douglas Self, some things got clearer, but the Mu-follower is not described in the book.
But Nelson I suppose himself started with Aleph configuration and the disadvantages do not seem very important. I know Vgs and so on, no headroom etc. but its worth a try (only a bit expensive🙂).
I quote once again: ".....The most important topological difference is that the output stage current source is no longer an “Aleph” current source, but a version of the classic “Mu Follower”. This approach was chosen because the JFETs can take better advantage of distortion cancellation than Mosfets, but won't do so if the current source is tightly regulated. This has a little less precision, but lower distortion .... "
may be this solution only has higher distortion but seems to work pretty nice!🙂
This is a good description: http://www.freewebs.com/valvewizard1/mufollower.html
You can understand why Mu! In Germany it is the sound of a cow!
and once more a quotation from Nelson:
"You can drop the JFET into the Aleph circuit, it's just that I
found the mu follower to operate a little better with the lower
Vgs. Not a big deal. You can easily adapt the board in any case
with the npn as the voltage reference."
post 393
http://www.diyaudio.com/forums/pass-labs/151909-firstwatt-j2-40.html#post2079858
post 393
Sorted SemiSouth Depletion JFET R085 Sorted.
20v 10R ~2A
D1 .332
D2 .334
D9 .335
D7 .336
D8 .337
D6 .341
D3 .342
D5 .344
D3 .345
D10 .356
Thinking I will keep D8 and D10.
20v 10R ~2A
D1 .332
D2 .334
D9 .335
D7 .336
D8 .337
D6 .341
D3 .342
D5 .344
D3 .345
D10 .356
I changed the gatestoppers of the Semisouth R100 to 50 Ohm, soundbalance got in the right order.
Thanks for the hint.😀
Thanks to tea-bag for selling these wonderful parts!🙂
Current stock
SSR085 - only one pair left. $70.00pr
SSR100's - 4 pair left. $60.00 pr
IXYS6N50D2's - 5 pair left 10.00pr.
Still have one pair left of R085s.
Once I clean out of SemiSouth's I will put up a GB spreadsheet for more.
I have 3 pair left of the IXYS's.
yeah, need more than a single pair. so will wait for the next round for RO85. will look up the IXYS part datasheet and get back to you later today. if you dont hear from me by the end of the day just pack up the PCBs. i'll check in tomorrow night my time a few hours earlier than this
- Group Buys
- Tea-Bag's IXYS Depletion Mosfet Group and SemiSouth R100 JFET group buy.
