TDA8954 at 4ohms bridge
There is a note that those stereo half bridges of that chip can be made to full bridge mono. At 8 ohms with 420 watt of power. Now I want to connect 4 ohm speaker there.
It should just take lower voltage to reach that 420watts and not to hit current limit. Current plans would be feed it with 30+-(maybe it needs even less?).
What ya think? Will it instantly explode? 🙂 Would it work?
http://www.nxp.com/documents/data_sheet/TDA8954.pdf
Current limit of 12A and each drive would see 2R.
4R speaker impedance curve would dip below 4R. This would make the current limit come on even sooner.
So at 8R BTL they can run +/-42V.
For 4R BTL perhaps +/-21V might be a good start.
IMHO
