I want to try a class D amp with an tube pre-amp/buffer and the TDA8920BJ is my best option.
the title says it all 🙂
I would not suggest copying that PCB layout. It is just bad, and overly complex anyway... the more you look at it the more you begin to wonder... I would have to assume it was mostly auto-routed by software. Anyway, layout is very critical for class D DIY. Study this site for suggestions. Good luck.
You may have a look on this Class-D amplifier using TDA8950J in bridged mode:
http://www.diyaudio.com/forums/clas...tda8950j-based-4-channel-power-amplifier.html
The PCB is single sided.
It is working like a charm, has powered many parties since the last months 😉
