Hey!
I'd like to use a TDA8510J chip I got from a Creative 5.1 speaker system to build a simple amplifier for a 4ohm 20W driver. I drew the schematic below based on the schematic at page 11 in the TDA8510J datasheet (http://goo.gl/8kSxZf). The volume control part is from this site: ESP - A Better Volume Control.
Would this work? If, not then why? I'd like to learn!
EDIT: power input 12V, line level audio input
on first site it should work.
Thanks. I'm now waiting for a couple of components to arrive so I can try this out.
Ok, now I got somewhere. When I applied voltage to the mode switch on pin 14 the circuit works, exept it's making a very loud humming sound. Any ideas how to fix that?
Looks like it's coming from the stereo amplifier. Disappears when the volume is other than 0. The audio volume is still very low, but some progress is better than none
i have also creative sound system in which there are 2 ic
one is tda 7372 and other is tda8510j
when i connect 14pin of tda8510j my whole sound system stop giving output
when i remove it only tda 7372 work (4 speaker work ) 5th speaker and woofer isn't working at any condition
any help would be appreciated please
thanks alot
thanks alot
- Chip Amps
- TDA8510J subwoofer amp
