TDA7498
Hi, I don't know much about class D amps, i've only had experience with car amps/woofers.
I have a leftover speaker Clarion SRE6942R, which is a 4-way 6''x9'' oval. It puts out 100W RMS/550W MAX at 4 ohms. The frequency range is 25Hz-35kHz.
I was thinking of building an enclosure for it and powering it with a class D amp for home use. I found this cheap amp with it's manual but I have a few questions.
Digital Amplifier 100W Board Amp Board with Radiator TDA7498 100W High Power | eBay
http://www.st.com/web/en/resource/technical/document/datasheet/CD00244535.pdf
So, can I bridge the two channels into one at 4 ohms and how do I do that?
How much RMS will it produce and how much volts do I have to put in?
Finally, does it have any frequency filters that will protect my speaker?
